Sylvania LC320SS8 32 in. LCD Television Logo
Posted on Oct 27, 2008
Sylvania LC320SS8 32 in. LCD Television Problem
I cannot program the optimum cable remote, none of the codes work.
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on May 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
6529
Points
17
Here are some 3 digit codes that are suppose to work for the sylvania tv's
070,003,052,059,060,063,064,127,160,164,044,056,210,236,238,243,168
  • Anonymous May 11, 2009
    I did some research and have found the way to auto-search for your tv's code.
    prees and hold at the same time the tv and sel buttons. the io button will lite up now press and hold the + or - channel button, the io button will blink when the tv shuts off, press the mute key. If you have the right code the tv will turn back on at this time press the tv button to lock in the code. now you can use the info series to find the accual code. press and hold the tv and sel button, when the io button come on press the info button and count the serries of blinks 1-2-3-4-5-6-7-8-9-0, depending on the number of blinks tells you the codethe code is a three digit code.
Need my sylvania remote to connect with comcast
Download the user manul of the remote you have, if the codes for the TV do not work, you will have to use 'search for your code' function.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
1helpful
Comcast remote control won't turn on or off Sylvania LC321SS9 TV
Usually you need to make the remote search for the right code that will work with your TV. Google you Comcast remote model for instructions and it willl how you the right steps.
1helpful
Sylvania LD320SS8 HDTV Can not program COMCAST Remote Control.
try the various codes listed for phillips. that should cure your problem. if not try sampo.
2helpful
3answers
Codes for sylvania tv
Unfortunately, there are no compatible universal remotes with this television.
2answers
Tv code for uverse remote
THRER IS NO CODE THAT WILL WORK WITH THAT MODEL I EVEN CALLED SYLVANIA AND THEY TOLD ME THERE ARE NONE
Unable to program my comcast cable universal remote.
I had the same issue with other devices and found out that the remote requires 5 digits instead of 4, so you need to add some digit at the beginning of the code. A lot of times it's 1, but sometimes is 2 or 3. Try the same codes listed on comcast's page, but entering a one before entering each of the codes. If that still doesn't work then try the number two and three and so on.
We're looking for the code number to program our universal remote
Find out what company makes the remote. Do a search for that company along with the search words: remote control tv codes. Their web site should be happy to help you with a list of all the tv codes.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
