Euro-Pro Shark GI475 Iron Logo
Posted on Oct 27, 2008
Shark euro pro G 1400z
How does one turn off this iron?
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Dec 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4224
Points
5
You must pull the plug to turn off this iron!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
333
Points
How do you replace the light bulb on a shark euro-pro iron?
How to remove back cover of Shark Iron?
6 screws hold the cover on, 4 are visible, two are under bumpers on bottom. pry out the bumper.
3helpful
Was using my Shark x-tended steamburst Euro-pro iron G1490 and it turned off and won't turn on
I had the same problem. The repair took less than 15 min. I opened the bottom of the iron and discovered what appears to be a design flaw on the cord holder/fastener. The holder is wedged so tight that it pinched the cord wire almost in half. I removed the cord, cut it off at the pinched spot and reinstalled. I also put a small piece of rubber onto the part of the holder that is made onto the body of the iron. In addition, I rotated the fastener cap so that the smooth side of it is against the cord.
Shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
Euro Pro Shark Iron
Thank you for taking the time to warn us and others about the euro pro shark iron. I will help spread the word.
Aug 10, 2009 • Irons
1helpful
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
I have a brand new Shark G1490. When I plug it the light turns on, but it does not get hot and besides this brown water comes out. what should I do? please help me.
push button down on top of iron to turn on iron and adjust settings and do a self clean to remove debris and scale build up from iron
1helpful
Shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Top Euro-Pro Irons Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
