Water some how gets back into diahwasher thru drain tube
Dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
water flowing from kitchen sink passes the opening of the dishwasher pipe
If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
The installation instructions suggest this
but often the dishwasher is at the end of its 'stretch'
and the installer assumes looping is just to use up excess hose, and doesnt.
an extension drain hose is available at most appliance stores
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
