2006 Volkswagen Passat Logo
Posted on Oct 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Volkswagen passat 2006 fuse box layout
I have a Passat 2006 and I'd like to have a diagram of each component in the fuse panel located in the engine compartment on the left side. The owner's manual is not giving all the information.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8391
Points
Over used the horn . now it wont work . replaced the horn and it still wont work and fuse are ok ???
Colin Stickland
Level 3:
  • Volkswagen Master 22,516 Answers
  • Posted on Nov 22, 2008
Colin Stickland
Volkswagen Master
Level 3:
Answers
22516
Questions
Helped
6995808
Points
66324
Works manual only ,not given out to stop weekend mechanics form working on cars,
2012 Volkswagen Passat. Which fuse is for the cargo light on it please.
It has hundreds of fuses and none marked 'cargo' or 'trunk'.
Volkswagen Passat B7 (2011-2015) fuses and relays
https://fuse-box.info > volkswagen > volkswagen-passat...
Here you will find fuse box diagrams of Volkswagen Passat 2011, 2012, 2013, 2014 and 2015, get information about the location of the fuse panels inside the ...
Fuses and relays Volkswagen Passat B7, 2010 - 2015
https://car-box.info > fuses-and-relays-volkswagen-pass...
Jan 27, 2021 - Fuse box diagrams for Volkswagen Passat (B7; 2010, 2011, 2012, 2013, 2014, 2015 model year). Photos, layout and assigment of electrical ...
2: Glow plug control unit (457)
4: Low power relay (53)
1: Starter relay 1 (643) - only for vehicles with
2answers
2012 Passat horn quit
Use a voltmeter at the horn connector and have someone press the horn button. If you see voltage at the connector, then the horn is bad. If you don't see voltage, then either the relay is bad, the clockspring, or the horn button is bad
Need fuse box diagram for 2006 volkswagen passat
On this website (link below) you find fuse box diagram and description for Volkswagen Passat B6
http://www.autogenius.info/en/volkswagen-passat-b6-fuse-box-diagram
1helpful
2answers
LOCATION OF FUSE FOR FRONT PANEL CIGERETTE LIGHTER 01 PASSET
Hello earl_webre: My name is Roger and I will help you. The only lighter fuse listed in the fuse panel diagram shows fuse 33 as being the correct fuse. The fuse panel is located in the left corner of the dash. See picture. Should you need further help please just ask. Please rate the answer you received. Thank You for using Fix Ya. Roger984bfbf.jpg
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
