You could not use WIFI with your phone because C2-01 has no Wireless configuration.You can see the details from this link Nokia C2-01 -.Thanks for visiting fixya
Ur handset don hav wifi dude.
SOURCE: how to change memory in use for messaging for
Select the settings > Phone settings > memory > saved location > select phone or sd card which you like.
Hope this helps, thanks!
SOURCE: I have a nokia C2-01 and I cannot find where to
Go to - - you can change the date and time here.
SOURCE: is there a code/s to unlock nokia c2-01 to any
Try this site to a friend is more secure guaranteed to get the correct code:
http://www.mobile-unlock.net
SOURCE: i cannot connect my nokia
Download the latest nokia pc suite, install on the computer the you will be using, connect your phone via usb the launch nokia pc suite the clik on connect then you be asked to select the type of connection, choose cable then the application will be able to coonect to the pc
Thank you for using FixYa!
I hope that I helped you & that this post id helpful to you at most!
Don't forget to rate! :)
