I have a 2002 c320 mercedes benz and i can get my key in the ignition wont turn
Just replaced my key the ignition switch and the esl in my c230 98 Benz. Worked for about a week and now the esl will not unlock the steering or start the car. Is there any way to reset the esl? All three components are new I don't understand the problem .what causes the esl not to engage when you put the key in the ignition
SOURCE: 1999 Mercedes Benz CLK Old and New Key will not turn ignition
hi,seem your esl or electronic steering lock mechanism is defect,since you replaced with key,ty
SOURCE: 1995 Mercedes Benz C220 will not start, and key
hello,steering lock mechanism and your key need to replaced,if you want try to remove your under dash,steering lock mechanism have a small pin(around 5 mm) which pit to steering housing,drill out the lock,then try to turn steering wheel,ty
SOURCE: I put my key in
There's a good chance the key is worn or the ignition lock. If you don't have another key you can order one through a Merc dealer via the chassis number.
Cheers John
SOURCE: 2002 MB C320 gas cap problem
I had the exact same problem, went to the Mercedes dealer and they fixed it for free with a pair of pliers. They just pulled up the metal clips and turned them back into place.
SOURCE: Mercedes Benz c220 ignition will not turn.
Did you try jacking up the car at the front then wiggle the steering as you turn the key? Did you try a spare key? Spray inside the mechanism with WD40. Try putting the key in at different depths and turning.
The lock cylinder is a replace only item.
