SOURCE: Mouse driver
GOTO THE HOME PAGE OF THE PRODUCT AND LOOK FOR SOWTWARE DOWNLOADS/DRIVER DOWNLOADS
SOURCE: Logitech wireless keyboard doesn't respond
Ok, try this. Remove the batteries from the keyboard, just type anything randomly for about a minute on the k/b keys (doesnt have to make sense) Just press as many keys as you can. This will discharge the capacitors and reset the k/b. Reinsert the batteries, making sure they are in the correct alignment (try to use new batteries if you can) and connect to reciever. Press the connect button on receiver first, and then press the connect button under the keyboard.
If that still doesn't work, then your keyboard is most likely defective. Make sure you have reinstalled the k/b software first from Logitech..
I also had a non-responsive keyboard that worked for a couple of days after installing. I purchased the unit over a year ago due to a great price. Since it was most likely out of warrantee and new batteries did not help, I open the unit and found a cracked solder connection on the positive battery terminal. I re-soldered the connection and it now works great.
SOURCE: Logitech wireless mouse and keyboard
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
