This is straight from the repair manual.
204 Final rinse time Parameter 4 ... 30 s. 7 Duration of booster pump activation (running time limited by P306!!).
306 Maximum final rinse time Parameter 0 ... 30 sec. Maximum booster pump running time (rinse) (limit of P204)
Booster heater pump does not work Check power supply to power rinse pump. Check pump rotor and replace 203/204 pump if necessary. Check start capacitor and replace if necessary.
Hope this is of some help.
This error code 204 caused by misconfigured system files in your operating system and window system file damage. If you are facing a this error code then you should download Error 204 repair tool.
Dial 1-800-204-4427 US Toll-free Number & Get the best assistance for Trusted Apple MacBook Technical support. We proffer an online MacBook Technical Support assistance to the customers and fix their glitches in a professional manner. Read More.. Apple Customer Support Number 1 800 204 4427
If the phone is getting restarted then you will have to reload the OS of your phone. You can download the phone OS from :http://us.blackberry.com/support/apps-and-software/desktop-and-device-download-sites.html select your carrier and the desired OS for your phone as you wish. then download the application loaded which helps you to install the OS to the phone from your PC. We call it as BBSAK (BlackBerry Swiss Army Knife). You can get the loader at : bbsak.org/download.php Once you are done downloading the both. Install the BBSAK and the Phone OS to the computer first where you downloaded from the blackerrry site. Connect your phone to the PC via the Data cable and wait a few seconds. Now open the BBSAK software and click CONNECT. As soon as you do it your phone's IMEI number will be displayed there. So now click Wipe device and press o for any upcoming messages. Now look at your phone, you will see a message saying that the phone is getting wiped (Resetting). Wait a few minutes and once the wipe it done Click on LOAD OS on the BBSAK software and then you will get a menu to select the Blackberry OS that you have installed in the PC (Remember i said that you need the Blackberry OS to the PC first). So now select the OS and then click Next and the rest is just a few steps left with some more Next clicks. I hope you are now done with the New OS installed to your phone
