My husband just received a C1500 nordic, he states their is a loud knocking, banging popping sound, he also noticed the base on the right side is not secure, along with 2 missing spring wheels, he states the noise is coming from underneath the rubber belt when the machine is on, this is brand new he just received it, any thoughts for all these issues?
SOURCE: i have a nordic track c2255 - having belt issues
Hello there, Your are perfectly fine by making that adjustment. That is actually what it is for. When the belts get older and start stretching you can move that spring and get more tension. It does not harm the roller or the drive motor.
Godd Job! Tim
SOURCE: I have a Nordic Track Audio Strider 900 and I have
sounds like your hub crank bearing assembly, damaged bearings / worn crank shaft
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
SOURCE: Hello, I have had a Nordictrack Apex6100xi for 8
Hi, According to your problem first check the deck where exactly it get loose. Open the deck and lubricate the roller motor. check all of the nuts if any one loose. reset the system.
SOURCE: My Nordic Track 1300 Commercial elliptical makes a
Dear Sir:
Thank by your request, I hope everything is o.k
I will try to help you, inmediately.
1)
Pedal Arms
Use aflat screwdriver to unseat the tabs that hold the front top cover in place. Thiswill expose the flywheel and pedal arm connection points. Rotate the flywheelby hand and determine whether lubrication will accomplish the repairs. If thebearings are exposed, use a grease gun with an extension nozzle and lubricateboth bearings with lithium grease. If the bearings are damaged or sealed,proceed to the next step.2
Removethe front and side covers on the main frame. Hold the flywheel with one handand use a box wrench to loosen the bolts that secure the pedal arms at eachside of the flywheel. Pull the arms away from the flywheel and remove thebearings from each side.3
Test thebearings as before. Lubricate exposed bearings with lithium grease andreinstall them. Sealed bearings must be replaced. Reattach the pedal arms tothe flywheel. Replace the main frame covers and front top cover to complete therepairs.
If you need further assistance, please reach me.
Thank you in advance, sincerely. God bless you.
E.CUADDRA
MANAGUA, NICARAGUA. C.A
