I have no manual or code numbers to enter for the living solutions 3-in-1 remote control. Need numbers for, and process on how to enter the numbers for a older 62"PhillipsMagnavox projection t.v., a Hitachi VCR, and a Apex DVD player. Please hurry. Thank you
I had trouble programing the living solutions giant remote - c17g0801.
But after many times serching I ran across a genius' resolution (maybe it was 2 genius') -
Jumbo Remote:
Make sure you have device turned on.
Hold the device button you want to program for 3 seconds & release.
Push & release the power button & the red light will remain lit.
Push the CHANNEL UP button over & over slowly until the device turns off.
When device turns off press OK button.
worked great except I have three inputs and it only gave me 2 to select from. Any suggestions? My email is [email protected]. Would appreciate any and all help! Thanks. Tony
This worked great, however I have three inputs and it only gave me two input choices. HELP!!! Would appreciate it!!! :O)
Goto remote-codes.com
I have the living solutions giant remote manual scanned and saved. If you need it just email me at [email protected], I was going to post the images, but it only allows 150 kb per pictures. PLEASE NO SPAM!!!!!!!
Http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/living_solutions/colossal-manual.zip&area=other
This is the entire manual.
Thanks a million yeeehaaa! This solution also works for televisions which are off and unable to be turned on via the power button. I have a sanyo on which the power button housing was pushed in making it next to impossible to use to the button. Using the directions given above I was able to use the remote to turn on the t.v. once again =). Thanks again! Hope this is helpful.
i need code
i have the same issue
