Question about Proton MM2701VT 27" TV
My rca screen turned green then shut off - Proton MM2701VT 27" TV
    New Friend:
  • 3 Answers
Open up and check for a dry joint at variable settings on chronos to screen controller if all cables ok ( check for pin damage on connector first sometimes a misalined pin prob
Posted on Feb 21, 2012
SOURCE:
RCA D52W20B F013C30N4 when turned on the image it green
Does the set continue to play normal except for the green being too pronounced ? Or does the set turn bright green with curved lines then the set shuts down? Let me know and I will assist you.
Oct 15, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
Tv shuts down after about 5 seconds
Sounds like the green CRT has a short.If you unplug the socket from the green CRT tube (the one in the middle) and power up the TV and it stays on then it will verify that you need a new green CRT.
Jan 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
RCA D52W20 52 in. Rear Projection
the main pwr board is defective and will need replacement...
Oct 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Proton MM2701VT 27" TV Logo
22 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
