Whirlpool ES5FHAXS Side by Side Refrigerator Logo
Anonymous Posted on Feb 21, 2012
Hi my American Fridge Freezer, after moving it and starting it back up, it seems to be going up to its freezer limits digitally also fridge, but when we open it the fridge freezer, ant cold at all. Any ideas welcomed.
  • 4 more comments
  • Anonymous Feb 22, 2012
    Hi there and thank you for your help,The fridge was never laid down, just pushed about.i have done what you advised me, but still its the same.
    Anymore help would be appreciated.
  • John Tripp
    John Tripp Feb 22, 2012
    Pull away from wall where you have refrigeratorn plugged in andremove lower cover on back that provides a air circulation wall and protective cover to compressor and with your hand feel the compressor. Is it warm, cool or too hot to keep hand there or can you sense nothing running but the fans? Sometimes the fans make it appear as if compressor is running. Is ES5FHAXS your correct model number? I feel you have most likely pulled something loose during moving around.
  • John Tripp
    Once you have looked over the area of the compressor I need someone to unplug refrigerator and lower the control panel inside the fresh food compartment. There is a defrost control board located inside the control panel. Look it over for signs of heat, melted solder or burn marks both sides. http://www.repairclinic.com/PartDetail/D...
    Below is a PDF parts manual
    http://www.kitchenaid.ca/assets/pdfs/lit...
  • Anonymous Feb 24, 2012
    Hi I took the back lower panel off. and the compressor, was warm to touch. I'm not sure i want to delve in to looking in to the electrical side of things and i didn't fully understand your last advise. Thanks.
  • John Tripp
    John Tripp Feb 24, 2012
    I thought it was possible your model is the ES5FHAXS like listed just above your post but the more I read below in your comments you appear to be in the UK. Basically I was seeing the American Model and hoping to find an answer for you. Sorry if I made you feel unsafe as I would never recommend doing something dangerous or you are not comfortable with. If fans are running warm air from bottom outside and cold air inside you have at the least a compressor working correctly. If compressor is warm not hot then itis possible Freon was released during the shuffle. I will continue to answer if need through my website email, Thanks John Tripp
  • John Tripp
    [email protected] Thanks and I will answer if you need me, JT
John Tripp
Level 3:
  • Whirlpool Master 4,656 Answers
  • Posted on Feb 22, 2012
John Tripp
Whirlpool Master
Level 3:
Answers
4656
Questions
Helped
1677632
Points
14883
You may have laid refrigerator down during the move causing oil to migrate to the evaporator. If this has happened leave refrigerator unplugged for about twelve hours so the oil can slowly seep back down to the compressor. Trying to speed this process up will slow you down and may cause the compressor overload to fail. Once the compressor is ready to start cooling you can leave refrigerator plugged in, Thanks Sea Breeze
5 Related Answers
Anonymous
  • 750 Answers
  • Posted on Sep 29, 2008
SOURCE: fridge/freezer not cool.
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Anonymous
  • 24 Answers
  • Posted on Oct 08, 2008
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Anonymous
  • 242 Answers
  • Posted on Dec 30, 2008
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Anonymous
  • 1902 Answers
  • Posted on Feb 12, 2009
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Anonymous
  • Posted on Jul 10, 2009
SOURCE: WHIRLPOOL AMERICAN SIDE BY SIDE FRIDGE /FREEZER
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
Bosch Series 2 KGN34NWEAG Fridge Freezer. The alarm sounding/not cooling in fridge compartment.
Call them out under warranty. the circulation fan is normally at the back of the fridge. On such a new fridge, so shouldn't need to be fixing issues. A fan is an 'electrical component', not an electronic item.
https://www.google.com/search?q=Bosch+Series+2+KGN34NWEAG+Fridge+Freezer+warranty
Refrigerators
  • Limited warranty, entire appliance, parts and labor (1 year).
  • Limited warranty for non-electronic components; parts only (1st to 2nd year).
  • Limited warranty for electronic components; parts only (2nd to 5th year).
  • Limited warranty for rust-through on stainless steel; parts only (lifetime).
Water dispenser not working and items in fridge freezing up in Daweo American style fridge freezer
It almost certainly needs a new thermistor, which is the electronic thermostat sensor.
Fridge Freezer temperatures fluctuating too much (I guess)...
The defrost timer normally only cuts in once every 24 hours. It sounds like your thermostat or temperature sensor is defective. The set back temperature should be about 2'C less than the set temperature.
1helpful
Bush American fridge freezer frozen fridge drawers and freezer temp cycling between -18 to -2
Refrigerator temperature may also change due to the door being opened too often, someone else changing the temperature settings. It could also be caused by a failed electrical component.
54helpful
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
2helpful
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
9helpful
Flickering display panel on Whirlpool american style fridge/freezer
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
3helpful
2answers
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 • Freezers
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
