SYSTEM WONT RE BOOT... THE DST SHORT DRIVE TEST [PRE-BOOT SYSTM ASSMNT] JUST KEEPS RUNNING... 0% COMPLETE {SCREEN HAS LOTS OF LITTLE VERTICAL LINES RUNNING LEFT TO RIGHT ] DONT KNOW WHAT TO DO.. IF I HIT ESCAPE, THEN MESSAGE "DISC READ ERROR" CTL ALT DELETE..THIS SCENARIO JUST GOES IN CIRCLES. PLS HELP.....
Please restart your machine and keep tapping F12 key from the keyboard
It will display a menu with options
Press enter on DIAGNOSTICS option
Let's confirm if the hard-drive is not gone bad
It will confirm if all tests are passed, you don't necessarily need to run the extended memory tests
Or you can also check in F2 menu (BIOS menu) during reboot
if the Hard-drive/SSD is detected on your XPS 13 notebook
Try to load BIOS defaults too.
Please reply back with the results.
SOURCE: Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
