Lenovo IdeaPad Y530 Notebook Logo
Posted on Oct 27, 2008
Lenovo IdeaPad Y530 - 40512SU screen is dark
This is a brand new Lenovo IdeaPad Y530 - 40512SU that I've only charged.. added Windows Vista to.. turned it off.. went to use 4 hours later.. and it's burning hot... plugged it in.. and now the screen doesn't work.. and it's really dark..
  • ddemails Oct 27, 2008
    Thank you for responding.. the bottom of the computer was hot and it was stored in a carrier even though it was turned off. Yes, it's under warranty and Circuit city is offering to exchange it back for a brand new one. Just curious if this brand is reliable like Circuit City says it is. Had problems w/Toshiba. Hewlett Package was not recommended saying they have a lot of problems with them. I want to stay in the $700 price range.. Do you have any recommendations? Apparently, this computer model is brand new.
  • Anonymous May 11, 2010
    Kind of a crappy solution. If it's brand new it should be under warranty, right? Did you buy it retail? Also, where was it hot, all over, the battery, the screen...? Does the screen display anything (is just the backlight out) or is the screen just black all the time?
Anonymous
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Oct 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
28910
Points
79
Have you installed the Lenovo EnergyCut drivers? Without it, laptop may not work properly and turns extra hot. Try letting it cool down before you try again.
3answers
Adjusting screen brightness on lenovo z500
Try this if you have Windows 8.1:
https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/Z400-Adjusting-the-Brightness-in-Windows-8-1/ta-p/1303113
37helpful
3answers
My lenovo z500 has a screen brightness issue. It very dim and it won't turn up no matter what I do?
Hi, I had this problem also and I don't know why, but Lenovo Ideapad Z500 seems to have some compatibilities issues with a new Intel video card.
So, what you need to do is rolling back the HD intel video card driver to the previous version OR go to the following path: D:\drivers\VGA\Intel\x64\9.17.10 and press Setup to install the old driver again.
That solved my problem. It's a shame that I can't upload this driver in my laptop.
In my lenovo ideapad u 160 easy capture camera is not functioning.
webcams do go bad. In my experience when a webcam stops functioning in one way, shape, or form it's usually the actual webcam that's faulty.
1helpful
2answers
Download webcam drivers
Download Here
For complete and updated driver just follow the link
*Brand: Notebook
*Family: IdeaPad Y510
*Operating System: Your Operating System
*If the driver for Windows 7 is not available you can use the Windows Vista Driver. Just make sure to check the version of the OS for Win7 32bit download Windows Vista 32bit Driver for Win7 64bit use Windows Vista 64bit
*You can also use Option 3: Lenovo Smart Downloading
*After Installing the driver press F5 + FN to enable the wireless switch
Thanks for using Fixya
2helpful
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
1helpful
Lenovo netbook wont turn on. It is brand new, and ...
hi! just a tip if its a brand new one try to isolate the problem check if it can actually run by removing the battery just by the ac adapter if still doesnt work then probably you have to charge the battery first if it still doesnt charge then probably there is somethin wrong with the power board. i suggest you call your lenovo tech support for further assistance. hope this would help goodluck!
After installing windows 7 webcam is not functining
Your lenevo IdeaPad S10 doesn't support windows 7 nor Windows Vista, so no drivers is available for your webcam.You might be able to install Windows 7 but only Windows XP drivers are available from IBM site.
If your system has atleast support Windows Vista and the drivers for windows vista might work with windows 7 as 90% of the drivers meant for Windows Vista works fine with windows 7,
Check out the chipset of your webcam and go to the manufacturer site and check if any updates are available from their side.
Good Luck..
Happy New Year.
Ensure that you did not press the conbination of keys that switches to the external screen, on thinkpads this is Function key , plus one of the numbers.
Check if the computer is in sleep (hybernate) mode, in this case you should be able to wake it up with the start button, or on some model with the wake up button.
IF you still cannto restart the computer, then it is probably frozen, remove battery and try to restart the laptop in this way.
After restarting check the power settings (you find them also on display properties/screensaver, or in the control panel). set the computer not to turn off.
If the computer screen does not turn on again doing the above, or there is no way to wake it up when it goes in standby, then the unit may be faulty.
If the computer is new, in this case, better getting a replacement or a repair.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
