My Fuji 4900 suddenly started displaying the !Card Error message. I tried the two Smart Media cards I own, after gently cleaning the metallic surface and both gave the same message. I then replaced the NP-80 battery thinking that might be the problem. The camera still displays the card error message and is unusable. I bought a new Smart Media card as the others had been used a lot and I thought that might be the problem. Even with a new memory card and new battery the camera still displays this message and won't work. It has been a fantastic camera and has given me great service. Can anyone find a solution to this problem? I need it desperately and can't afford a new one right now.
I hope if we reformat the pics in the memory will be gone. Iam not worried with the memory card but need the pics in it.Thanks again.
Try reformating the card- i formatted mine into FAT and not FAT32 and that fixed it
I have A Gateway T50 that was reading no card error also. Try fitting a small piece of foam rubber on the cover so that it presses the card in for a good contact. It seemed to work for me.
I've had similar problem when I was messing around with the Sony memory stick. The cheap pins inside that suppose to touch the memory got screwed up. I just bought the camera so took it back to the store and got a different one. Anyway, try shining a flashlight into the memory slot and see how the pins are. If they are not line up then use a really small something to re-line them like they suppose to. See if it's possible to reformat the memory. That sometime help too. It happened to my sis cell phone. We had to reformat the memory stick to get it working right. I do not think this have anything to do with battery. If you don't put memory in and camera say "No memory" and with memory in and it read "Mem error" then likely the reader or the pins are screwed up. Goodluck.
My digital Camera started to say mem error too. It's an SD memory. I used a regular sheet of paper and ripped it to the size of the memory and slide it in with the memory. The paper is on the side where the terminals contacts are to the memory. Seems like that clean it and camera worked fine again.
Goodluck.
I tried the suggestions, but still nothing works. I can see nothing wrong with the pins -- everything looks lined up. I have tried everything. Anyone else have an idea?
I want to thank both people who have taken the time to give me a possible solution. I just tried the paper cleaning method several times but the camera is still displaying the message. Anyone who has other ideas, I would very much welcome them.
when i operate my camera, the message appear 'card error' on my display.
i cannot use it to shoot or even to view the images. but when i open the card on my computer, the smatmedia card seems having no problem. Could you help me to fix the problem?
Where, in Milan, a can find Fyjica 4900 finpix memory cards?
i have same broblem
