All functions are ok. SIM is inserted in place. It worked satisfactorily since 2004. It has fallen off hand number of times. still it worked until recently when problem arised. Even though network is available display showed no signs of a net work nor bacame able to find any network even after manual search is enabled. The problem seems to lie with the antnna circuit. Can you help ?
SOURCE: Insert SIM Card
make sure the sim card can make good contact with the phone.
Also check if it doesn't have space to slide, causing it to loose contact with the phone.
SOURCE: my n70 is not showing the sim it says insert the
Might be sim socket pins are not set properly..Might be a hardware problem..Go to nearest dealer..
SOURCE: insert sim problem 1100,1600
sometimes it is as simple as cleaning the sim card and sim points on the phone with a pencil eraser. sometimes it is related to a simcard IC (usually placed close to the sim tray in the phone) so if u do not succeed cleaning the sim and sim points of the phone u need to change the simcard IC
SOURCE: nokia 6300 doesn;t work with sim card
Hi there, you may try to reset the whole software on your cellphone. Provided to back up all the necessary contacts, messages on your Cellphone. There is a need to update the software version of your cellphone to make it working again.
You
