1996 Volvo 960 Logo
Posted on Oct 27, 2008
1996 960 okay i was driving out of my neighborhood and all of a sudden i turned the corner and the little flashing arrow started on my dash and 2 of the 3 lights next to the shift knob started blinking back and fourth...what does this mean?
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Oct 28, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
9355
Points
33
Codes prob stored in trans control module. I would say problem is gear position sensor is faulty. It is located on the pass side of trans, next to cat. the wiring goes over top of the trans. It will need put up on lift to replace. prob a 3 hr labor job in shop.
I have a 2012 suzuki swift none of my turn signals work or hazards
NO VIN told, why post? lighting is not the same world wide by laws in every country so be wiring too.
flash fast means dead lamps or shorted lamps
car starts and runs and drives ok
head lamps all work only TURNS failing.
flash fast on dash and you did not look outside car
all 4 corners? really?
what if 1 of 4 lamps was dead?
the users guide tells you all that.
if flashes fast on dash look outside at the real lamps. turns;.
IT is a feature that flash rate is a warning,
and most are controlled by BCM body brain
that detects TURNS currents wrong, too high or too low. so you are alerted to fix it. now.
see?
NO VIN NO JOY, no books , no parts no service.
lacking a vin
the dealer will not talk to you lacking VIN
unless the car is smack in front if them.
see why? so they don't lie to you.
1helpful
745li has an intermittent starting issue. I open the door and hear a whining sound coming from near the rear passenger door then on the dash the arrows start flashing and the car won't start
Does sound like its the ivm witch is located under the hood on the passenger side against the fire wall you will see a large plastic cover with allen screws remove screw then lift the plastic cover off the ivm is located in the upper right hand corner of the computer it will simply unplug ....make sure to disconnect the hot side battery before unplug it and then plug the new one in. they costs roughly 95.00 for the part at advance or auto zone.
I have 2010 Kia Sedona that shuts off after I drove it less than 2 miles, I have to tow it then after two day starts a gain , i'm afraid to drive it on the road, What would be the problem?
I had a similar problem on mine, and found and after some head scratching found what the problem was, I'm not saying this is your case but certainly worth checking. Have you ever got into your car put the key in and it just cranks over but does not fire up, you then turn the key off and try again you might do this a few times then it will fire up okay and run, mine was like this and sometimes just cut out as I was driving, now as you turn the key on their is an immobiliser that comes on then goes off when started that's okay, but the times you sat in the car trying to get it started did the immobiliser light come on if not then the problem points to the transducer that sits around your ignition key switch as you put your key in this transponder reads your key and if it's the correct code your light comes on the dash then goes off when started as with mine I found that it was disconnecting itself and suddenly the car stopped, This is very easy to get to and remove so you can replace it if required, just remove the steering wheel shroud that's sits around the back of the steering wheel this will then expose the ignition switch assembly, on the barrel of the switch at the end were the key enters you will find the transducer it's easy to see as it as two small wires coming from it to a little plug for easy removal there is one small screw holding it in place.
Good luck
1helpful
2answers
I have a 1994 Volvo 960 and the arrow is flashing on the dash plus the W,S,E buttons are blinking and the car won't start now. What is causing this and how can it be fixed?
The lights indicate a problem with the transmission. The fact that the engine wont start, leads me to believe that the PNP (neutral safety switch) is the problem. You will have to have the vehicle scanned to make sure.
2answers
S light on dash car
It sound like a starter or selinoid problem or just the starter relay or fuse you will need to have starter tested and if okay then move on to your relay and fuses to see if any of them are bad.
12helpful
Flashing upside down arrow/ slow acceleration
This is a common problem of Volvo S40. You can try this trick to turn off the flashing arrow light.
1) Turn off Engine
2) Turn key to "On" position (Not start the engine), you will see the panel light will on
3) Step on the break paddle
4) Shift the gear from "P" to "L" 10 times
5) Turn key to " Off" position
6) Now you can start the engine.
7) If doesn't work, you can repeat the procedure.
Hope this tick help
Good luck
1994 buick lasabre died while driving! Wont start
it does sound like you are having a problem with an alternator.
2001 Volvo V40 arrow warning light
Most likely the transmission range switch is failing.
Have someone check the transmission computer for codes.
Top Volvo Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Volvo Expert? Answer questions, earn points and help others
