I forgott my self out of my android and cant remember my pattern or gmail account
SOURCE: kids was playiong with G1 and did to many unlock
If you cannot remember the username and password to your G1, there is not a way to recover it at this time. The only way for you to have your phone again is to do a master reset using the hardware buttons. This will delete all of your data on the phone only (SIM card and memory card data will be fine). To do a master reset power the phone off completely. Hold the home key and the power key at the same time while turning it on again. You will see the T-Mobile G1 screen first, but them you will see a screen with a triangle appear. You can let go of the keys and open the keyboard. Press and hold the left ALT key and then press the letter W. Release both the keys and the phone will power off. Then it will power on again and act like you just removed it from the box. Create your new account and write down the username and password this time that way you wont forget it.
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: Hi, I need help, I have SAMSUNG Galuxy S (I9000),
Do this but make sure you may wan't to lose files:
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 MATER RESET
Done!
SOURCE: my little brother was messing
dear friend,
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as ,[email protected]. Now this google id on the top right corner of the page would be displayed as[email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like[email protected]) into your galaxy s handset locked page, and type in the password.
or theres this one:
enjoy & Cheers
SOURCE: my samsung galaxy ace is
More than likely, you will need to reset your password for your GMail to get back into your phone. Go to Google.com to reset your information.
If you are unable to do this, you will need to do a Factory Restore to your phone. WARNING: Factory Restore will erase all phone data. It will restore the phone back to the stage when you first purchased it.
To restore your phone back to factory settings do the following:
1. Power down the phone.
2. Hold the Volume Down button and press the power button.
3. A menu pops up, release the Volume Down button.
4. Press and release the volume down button to select "Clear Storage"
5. Next, Press and release the power button
6. To confirm, press the Volume Up button
The phone will run some tasks and then reboot. You may then signin with a new Gmail account. I suggest recording your new account information in a safe location for future reference.
