I need the instructions for this please! Thank you!
The DR-550 MkII is the upgraded version of the venerable,
original DR-550. ... Also, as in other drum machines in the
DR-series, you can chain patterns to forms songs - In the DR-550 MkII, up to 8
songs ... Boss DR-550 Mk II manual. Available ...
www.synthmania.com/dr-550mkii.htm
Just checked this site. I am sure this manual is the one you want
SOURCE: Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
The beats you have programmed into the drum machine will not play through the midi cable. In order to do what you want you need to connect the audio output from the drum machine to the audio input of the br-1180. What you should then do is connect the MIDI out of the the br1180 to the midi in of the Dr5. This will allow you to start and stop the drum machine with the play button on the br1180. MIDI can be a complicated thing so be sure to RTFM about MIDI for both of your BOSS devices to understand what they can do to work together. Good Luck
SOURCE: I am looking for an instruction manual for a Boss
Google is your friend... it found:
http://www.bosscorp.co.jp/products/en/_support/om.cfm?ln=en&dsp=0&iStcd=4&iCncd=50
Download your own.
