D-Link DI 514 Wireless Router (DI-514) Logo
Posted on Feb 20, 2012
Can I use D-Link DI-514 to connect to leased line with 1 WAN ip and 4 IP pool
I Have a leased line with one WAN IP and 4 LAN pool IPs, how can I configure the device to use the LAN pool IPs provided by the ISP
5 Related Answers
peepnklown
Frank
  • 175 Answers
  • Posted on Nov 10, 2007
SOURCE: How to determine public IP
Your IP: http://www.ipaddressworld.com/
Anonymous
  • 9 Answers
  • Posted on Nov 20, 2007
SOURCE: DI 514 and Skyway
if A is the skyway modem with the adress 192.168.1.1
if B is the DI 514 WAN port with the adress 192.168.1.2 and 192.168.1.1 set as gatway
and if C is your computer with the adress 192.168.2.2 and 192.168.2.1 set as gatway
and if D is the di 514 LAN port with the adress 192.168.2.1
than it works
"When I route it through the DI 514 I can access the internet but not the modem" u dont route it, u NAT it. so if u cant acces it with the right setings then try to xpoze yor computer host in DMZ seting
Anonymous
  • 35 Answers
  • Posted on Sep 05, 2008
SOURCE: no wan light
If no wan light bypass the dlink router and check if ethernet cable connected to wan port is working. Once you are able to go online through modem connect cable to WAN if light does not go on log into oruter and clone mac address and save settings.If doesnt work powercycle router and turn modem on first then router next if doesnt work upload latest firmware.
Anonymous
  • 93 Answers
  • Posted on Feb 27, 2009
SOURCE: D-link DI-604
I didn't quite understand what you meant but Ill explain some stuff you to that might help.
From what I understand you have a dial up router/modem, which is external (outside of your computer/seperate), and you hookup your phone line to it, which then connects into your DI-604 WAN port.
WAN Static IP settings are related to the settings given by the ISP that stay constant. There are 2 types of IP, static and dynamic. I think dial up is dynamic, since you have to connect/disconnect through the phone when you want to get on, this causes the ip to change at each reconnect, unless your ISP treats it differently.
I have no idea what you want to get out of the WAN static IP settings, but this should be handled by the dialup router/modem it self, and generally you dont have to manually enter the static ip, unless the ISP requires it, in that case you would enter this stuff there. The ISP Gateway Address refers to the ISP's router address/modem, I think, since I never heard the term before.
After "My problem:", I didn't understand your problem and can't give you further info until you clarify. Also if you internet is fully connected and working, and you still have problems then you could try resetting the router, by holding the reset button for 10 seconds. This will erase all settings. If that doesn't help try unplugging the router, then holding the reset button for 5-10 seconds, then plugging it in at the same time, then it should be fully reset, unless I forgot how it was supposed to be reset. ( I used to have the same router)
Anonymous
  • 58 Answers
  • Posted on Apr 01, 2010
SOURCE: How to obtain new WAN ip-address
For the router it should suffice just to cycle its power.
However, the behavior of the ISP's DHCP server may also be part of your problem. Most likely, it also will try to assign the same address as before, if still available.
So what you can try is to switch off your router and modem for a few hours (e.g. over night) and see if you get a different address.
Of course, this won't work if you have a statically assigned IP address, as this is often the case with cable modems. In this case your only chance is to contact the provider and ask them to change your IP address. You should of course be able to offer a very good explanation then...
Wireless security enabled and lan not able to work together
Try to set up an IP reservation for your ethernet using the MAC address of your NIC, this way the router can't steal it for the WLAN.
Mkae sure that if the router is run as a DHCP server that there are suffcient on IP address range to allow extra PC's to be leased an IP address.
I suggest that you disable in WZCSVC on both your wired PC and wireless PC and use the laptops own NIC connection software and the routers WEP or WPA-PSK to allow you to connect your wireless
2helpful
2answers
Cant acess internet or wireless network,need passphrase
The IP address 10.0.0.1 is a default for some types of network routers including Cisco routers. open it in browser and make LAN and WAN setting of modem and Router Same and security passkey of wireless same ans of wireless lan card and DNS setting same [email protected]
2answers
How can i setup my dlink 514 router?
Connect one of your computer to LAN port, access the configuration page of the router (IP 192.168.0.1) for the connection type choose dynamic IP address, clone the MAC address then apply the settings, Check the IP address under status (WAN section if you have the IP address it means that your connected)
D-LINK DI-514 LAN Ports not working
  1. Connect a cable from your PC to one of the four plugs. Not the WAN port.
  2. Setup the wireless the way you want it.
  3. Then give this router a different IP, like 192.168.0.2
  4. Then you have to disable the DHCP server in the router (keep in mind now you have to set your desktop or laptop that is conencted to it to a static IP to still communicate with the router)
  5. Once this is done just plug you existing network into one of the four ports. Not the WAN port.
  6. It will now act as a wirelessa access point.
Althoug this is doable it is not recommended as this router is a pile of **** and the wireless is crappy.
I would suggest a dedicated wireless access point.
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
2answers
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Routing configuration
Contact an ISP for an IP address.
configure the computers in the 2 networks to have the IP address you got from your ISP as the default gateway..
Cheers
2answers
Two way routing.
You will always have a problem because the subnet is different. Your solution lies at the Server Level if you have two different servers one must become the 2BDC, other wise you will need more hardware to setup a bridge contact D-Link as to the equipment you will need.
Coach "J"
Have a great 2008!
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
