Question about ESQ Watches
I need band links for esq watch #300397A
I need watch band links
SOURCE:
SOURCE: Armitron watch band needs extra links
I just called the main headquarters and they sent me 2 links for FREE!!! 1-800-840-2933 my model # for my watch is 20/1897T1 found on back. Hope this helps :)
Posted on Jan 08, 2008
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
SOURCE: HOW DO I TAKE A LINK OUT OF THE WATCH BAND
Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
Posted on Aug 11, 2008
SOURCE: Remove links from metal watch band
This was on a Seiko Dive watch SKX007. This has the metal links joined with pins, which, you will find, are split/spring down their length.
I used a neoprene mouse mat as a work surface, which was ideal as it allows the pin to move out, whilst supporting the links and stopping any slippage. I also rigged a table lamp close by.
There is an arrow which shows in which direction the pin needs to be pushed to remove it. Look carefully and you see that one end of the pin is slotted a little, the other is plain. Push the plain end in the direction of the arrow firmly... it's a leap of faith.
As a tool, I used a cocktail stick to start with. It required firm pressure and then it suddenly gives. I was able to draw the pin out by hand, but used pin nose pliars in one instance, as some pins offer more resistance than others. In most cases the cocktail stick worked (I got through a few). I then graduated to a thumb tack which was more reliable, but metal to metal, so a bit more worrying.
Sliding the pin back was simple, though take care to get the smaller links the right way up when it is re-threaded. I pushed it home the last few millimeters with the flat side of the pliers, giving a final push with the cocktail stick. Good luck. Simplysimon.
Posted on Oct 01, 2008
I have a ESQ E5262 stainless steel and the band is a little tight. I am looking for a band link.
go to a jeweler or watch maker as they often have spare links from bands they adjust in shop when making a sale
take the watch in to match the links
Nov 11, 2015 | ESQ Watches
Tip
ESQ watch instructions/manuals.
Follow this link and click on OPERATING INSTRUCTIONS to get manual for your ESQ watch: http://www.esq-watch.com/support.asp
on Mar 05, 2010 | Watches
My band has broken, and I've lost two of the links. Can I get replacement links or a replacement band?
mcdevito75 here, Look for a small watch repair shop in your area for replacement.
Jun 29, 2010 | ESQ 7300698 Watch
I need more links for my watch
ESQ is Movado.
http://a3.geoserve.com/scripts/esrimap.dll?Name=L&Com=fo&Db=DLRMovall&Ds=Movado&Filt=User7%20LIKE%20%27_S%25%27
This link will provide you with an Authorized Service Center.
Jan 13, 2010 | Lucien Piccard 26024 Wrist Watch
I just need to remove 2 links and I do not want to damage the band... can you help me? ESQ by Movado
Take this to a jeweler or pound out the pins with a paperclip width rod of steel or pin pusher and a hammer.
Oct 16, 2009 | Lucien Piccard 26024 Wrist Watch
New band
You can either contact Movado directly (they make the esq watches) or you can ask any REAL jewelry store to contact the company for you and ask about this as long as they carry either Movado or Esq in their store (don't ask the jewelry counter at your local department store).
Dec 30, 2008 | ESQ Swiss Muse 07101116 Watch
How do you set time for the ESQ aerodyne watch 07301132 ?
i need to remove links from my sons fossil watch how do you do this?
Dec 25, 2008 | ESQ 07301132 Aerodyne watch
ESQ watch parts
Type in your browser: 1) ESQ watch bands
2) EQS watches
3) ESQ watch bracelets
4) ESQ watch parts
Try all of these and you will find numerous sites (too many to list here).
Dec 21, 2008 | Watches
Watches Logo
70 people viewed this question
Top ESQ Watches Experts
Arturs Kalnins
Arturs Kalnins
Steve Allison
Steve Allison
Are you an ESQ Watch Expert? Answer questions, earn points and help others
