Hotpoint Ultima WF865 Front Load Washer Logo
Anonymous Posted on Feb 19, 2012
Hi I have a hotpoint ultima wma74 and just last night the inner drum just started banging about. Does any one have any ideas what could be up with it? Thanks kev
  • Anonymous Feb 19, 2012
    Could it be needing a new belt or bearings?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 19, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
106
Points
Knackered drum mate
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
How do i fit the drive belt on a hotpoint wma74 washing machine
Hook the belt over the motor shaft and feed it onto the drum pulley as far as it will go,hold it in place on the pulley with the aid of cable tie clips, then rotate the inner drum anti clock wise by holding the inside of the inner drum. This will draw the belt onto the pulley and the cable ties will snap as the drum rotates.
1helpful
How to change bearings on hotpoint wma74
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
My Hotpoint Ultima WT960P has developed a very severe vibration under load on fast spin - how can I fix this Tom
hi there....most probable cause is a main bearing failuer..or a cracked spider unit at rear of inner drum.......both scenearios require a comleted strip down of the wash tub
regards Sir Galahad
1helpful
My wma74 Hotpoint WM door will not open
hi the error shows bcoz of ur door problem...replace the door lock and ur problem will be solved...
rate me
Hi our hotpoint ultima wma74 front loader sounds like a tank when drum is on a spin i think the bearing has gone but im not sure how to get the drum out do i need to take it outfrom the top or is there an...
The whole drum assy comes out through the front of the m/c.
It is required that you remove the top cover and front panel altogether, and detach everything that is connected to the cabinet and remove the hoses from pump and dispenser. It is not a job to be undertaken unless you know what you are doing.
How do I reattach/replace the belt that causes the Hotpoint Ultima WF860 to spin?
If you remove the back cover from the machine, you should see a big round pulley which attatches in the centre to the inner drum shaft. Below the drum you should see the motor. The belt goes around the big round pulley and onto the much smaller pulley on the end of the motor shaft.
Hotpoint Ultima WF840
all i can suggest with the info you have given, is to remove the lid and check for anything lose like the weight block etc also have you checked the inner drum for play, maybe the bearings have gone please not to all it is not safe to continue to run machines that are making noises, they can only get worse making more damage, what can start off as something silly can eventually write off the machine start with that and see how you go, glad to help, if i have helped please rate me
Drum
u need to put something like a wooden hammer handle into the hole in the spider at the back when u have put it in spin the inner drum clock wise fast so it undos the spider or pulley wheel to some people once the spider is all the way off u need to put the nut back on just so it is level with the spindle with a rubber mallet strike it fast and hard and it will move the inner drum to come out once it comes so far out u need to undo the nut and remove the inner drum totally
2answers
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
