I don't know how to open the battery compartment. I tried pushing it and pulling and everything so can someone please tell me how to open it??
SOURCE: Battery remove
Can you not hold the camera upright and it should fall a little bit to allow you to grab hold of the end and pull it out.
Otherwise it this isn't happening there may be a mechanism problem.
hope this helps.
Drew
SOURCE: Can't Find Battery.
The camera itself doesn't have a battery. If you have a light meter in the finder however, then the battery for it is in the finder itself. Press the button the back on the left side while at the same time, push the lever over on the finder. That will release the viewfinder.
Look underneath and you will see the battery cap. Unscrew that and you'll see the compartment. If it is an old FTn finder, then it will likely take the mercury batteries that are about 1.35V. They don't sell those anymore as mercury is illegal in consumer batteries, but if you do a search on eBay for 1.35V WEIN cells you should be able to track down replacement batteries.
You could put Duracell PX625 batteries in, but they ar 1.5V and thus will give inaccurate meter readings.
