My Ixus 130 was working fine but now it has permanently blurrd photos and screen. I have used the menu to reset it to factory setting but with no joy. Is there a 'hidden' factory reset function. I don't think it has been damaged or dropped.
SOURCE: how do i unlock my card in my cannon ixus 75
Remove the card and look for a tiny slide switch on the side of the card. Slide it to the other "unlocked" position, and reinsert it in the camera.
SOURCE: On a Cannon Powershot IXUS 86015 How do i change the language back to english?
Hey thaze,
According to the manufacturer you need to press the playback button, which looks like a triangle pointing to the right. Next you need to hold down the func. /set button, and press the menu button. Next you need to use the up/down arrows, or the right/left arrows to choose the desired language and then press the func. /set button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Cannon IXUS 40.Saying, Card Locked.
In case it uses the SD card, then there is a lock feature in the card.
You will need to unlock the card so that it becomes read/write enabled.
In lock position, it is read only, so you can read the files from it
but cannot create any more files.
Most SD cards have a switch on the edge of one side of the card.
Sliding it up or down will unlock or lock the card. When the card is
locked, you will not be able to transfer any audio tracks. Nor will you
be able to play any copy protected files. We recommend you always keep
the card unlocked.
NOTE:
We have found that on some cards, if the slider is even halfway towards
the lock position, the card will be locked. Make sure that the slider
is all the way to the UN-locked position.
SOURCE: i am not gettin any
Check your settings in the menus. If you've muted the camera to remove the other sounds, it will mute the video soundtrack as well.
SOURCE: can i use my canon
No. The IXUS 130 is designed to store images (and videos) to memory, not to stream live video to another device.
factory reset
