I changed my battery , km and clock is flashing.Why?Please help me
SOURCE: 2003 alfa romeo spider electric roof does not open
Thank you Thank you Thank you.. The tapping of the motor in the battery compartment really worked.
Thank you kindly.
SOURCE: Alfa Romeo Selespeed 156. How to drive uphill in traffic.
Left foot braking technique shold solve your problem!
SOURCE: need electrical wiring diagram alfa romeo gulietta 2.0 executive
Could some one please help. what is the name of this square box above the fuel tank inside the boot of the Alfa Romeo Spider Tourer 2000. how much to replace? thank you many.
SOURCE: alfa romeo 156
2003 Alfa 147 2.0 TSpark.
Hazard lights and indicators will not work. all lights flash when central locking is activated. Changed the fuse but didnt solve the problem. All other lights work when activated.
SOURCE: to code engine immobiliser on
(1) look behind fuse box (2 x 10mm bolts then ease it downwards), look for black box with green sticker behind fusebox, unplug and replug wires (white plugs) several times, they suffer from corroded connections. (2) wiggle wires around that box and fuse-box. (3) take it to Alfa dealer for check-up, if parts and re-code needed usually around £250.
