My Laptop Dell Inspiron 640m doesn't have hdmi port. My TV is Sony Bravia LCD with hdmi ports.
Your tv should have vga port. if not you can buy a vga to hdmi adapter
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: How do I hook up the HDMI cables to a cable box
how do i hook up hdmi cables to cable Sony KDL Bravia LCD HDTV
SOURCE: Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
SOURCE: I have an HDMI cord hooked to my Bravia it is set
if you have video im assuming you do if you can see its on video 6 look at hdmi port and make shure its video 6 if your not shure leave it hooked up the way you have it turn on cable box and go thru all inputs example put it on video 1 wait for 60 seconds if nothing happens go to video 2 and so on and so on be shure to wait at least 60 seconds before you change to another input good luck
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
