SOURCE: The bluetooth turns on using FN + F11 it should
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
Bluetooth LED indicator glows blue when Bluetooth function is enabled.
Both LED indicators glow green and blue at the same time when both
functions are enabled.
Both LED indicators go out when both functions are disabled.
Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
SOURCE: u100 msi wind netbook, webcam problems
i have same problem pls sant driver u100 webcam [email protected]
SOURCE: i have msi u100 netbook.i
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
