How do I set up receiver to send video out to my hdtv. I have all the component video going in to the receiver, but am in a quandary as to how to get the video signal out to the tv. thanks
It depends on your tv, you will not be able to get hi-def through this reciever(to old).
If your tv has an s-video in that will be the best you can do with that reciever.
Get back with me and I will walk you through hookup.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Pioneer VSX-D606S subwoofer set up
If you push the middle of the remote the select I belive it it it will give you options on the receiver. There is one which says subwoofer on / off. Hope that helps.
SOURCE: Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
SOURCE: Owner's Manual - Pioneer VSX 455 Receiver
It should be compatible with all of them. I have one that works just fine with my Sony HD/TV, HD DVD PLAYER, etc. The only difference is that its is stereo w/ a middle speaker hook up, if you so desire.
I find it just as enjoyable and easy to use as my Denon 6.1 with fewer speakers. That is because as men, our hearing range is poorer especially as we grow older.
Email me with any other concerns you may have.
Thanks,
dthomas
Chicago, IL
[email protected]
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
