SOURCE: jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
SOURCE: I know I can take a bath without turning on the
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
SOURCE: jets not working in my ten year old jacuzzi bath
Open pannel and look for a reset button on or near the pump motor.. Or it is posible that the pump motor is shot..
Have a great day !
SOURCE: my jacuzzi baths pump makes a noise when i turn it
you have a bad pump. has a bad spot on the motor, that is why it doesn't start. What model number of pump?
SOURCE: whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Rod Kidman
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
