My dvd r/rw drive will not open
Click Start menu
On the right under your user icon you will see Computer or My Computer
Click there, you will see a list of drives in your computer
Right click on dvd drive and choose eject
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: DVD - RW WONT WORK -
Unfortunately optical drives do have a short life span, you can buy a replacement from newegg.com so cheaply these days its not worth messing with the old one.
I have just bought a DVD-RW dual layer OEM (so I had the burning software with it) for a new build I am doing for $28 plus delivery.
SOURCE: help fitting a dvd rw to a dell dimension 3000
ok
i can try to help
i think u can remove the from panel
for that u will have some locks or screews remove that
then u can fix ur drive on the top panel
let me know how it is
if possible
SOURCE: CD/DVD-RW Drive
Hi! Buy a Samsung/LG/Any Other Brand 40-pin connector IDE CD/DVD-RW drive. All IDE Drives are compatible with your Dell Dim 3000
SOURCE: what kind of serial interface do I need for a new
Should be just a straight ribbon cable, you can use either a 50 or an 88 cable, on a 50 the dvd must be set as master using the jumper configuration. On an 88 you just set the jumpers for cable select and make sure that you use the furthest connect on the ribbon cable from the device as your master. Nothing too complicated about it.
SOURCE: I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Testimonial: "thanx for your help you fixed it!"
