Press the num lock key
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: laptop 6 keys are typing number instead letters
Your Num Lock is on. Press the Num Lock key and that should turn it off and you should be able to type normally again.
SOURCE: function keys
Hi you need to hold down the function key (FN) and press the number lock key (num lk). hope this helps
SOURCE: Keyboard problem with IBM R52
Hold the blue fn key (function key) then press the numlk (numbers lock) this will enable or disable the calculator feature on the keyboard.
SOURCE: activation of the number pad so instead of
Hi, try pressing the numlock key - this should put the number pad as standatd until it is pressed again, when it will revert to letters.
Great solutions, Thank you. I found that on my IBM ThinkPad R50e I need to hold down the "Shift" key before pressing the Number Lock key to disable it.
