SOURCE: gateway notebook key fell off keyboard
Unfortunately, there is no instruction out there for this. My advice is to take one of the other key off in order to see how it fits, then put the key back on the same as the other. I suggest a key right next to the one that is off. Be very gentle and try to remove only the key, leaving the retainer.
SOURCE: Need keyboard hotkey drivers for Gateway 7210GX
GO ONLINE AND TYPE IN THE ADDRESS BAR:
GATEWAY 7210GX HOTKEYS DRIVERS
WWW.WINDRIVERS.COM/HOTKEYS
WWW.WINDRIVERS.COM/DRIVERS/HOTKEYS
WWW.DRIVERSHQ.COM/HOTKEYS
WWW.DRIVERSHQ.COM/DRIVERS/HOTKEYS
WWW.UPDATEDSOFTWARE.COM/HOTKEYS
WWW.WINDOWS.COM/DRIVERS/HOTKEYS
SOURCE: Gateway- built-in laptop Speakers not working
Heat dissipation from the unit in the same area of the speaker assembly, especially since you stated that the RIGHT speaker was smoked. Similar problems occur with this design flaw with any manufacturer as HP has the same problem with some of their models.
Your heat exhaust is killing the speaker, and I would also bet that your chipset is AMD and not Intel, the latter having solved it's heat dissipationn problems.
A more aggressive heat dissipation solution on the motherboard or redirection of the exhaust past fewer heat sensitive components would be a design goal.
SOURCE: Fn key problem with Gateway notebook
Hey there, this is an easy fix, just press the num lock key:) let me know if for some reason that doesn't work
seth
