SOURCE: hi, I am currently using HTC
If you have take new mobile means in the box you will get a CD that is called as a PC suite you should instal the pc suite for your system after that you call the services provider for you smart phone there you can ask that person to send you the settings for internet.They will send you the settings at that point of view you should save that settings after that you should make some changes in your pc this information will be provided from the service provider then you should switch off your phone for a few minutes after that you switch on then connect your phone to your pc through data cable or bluetooth and now you can enjoy using the internet. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
SOURCE: how HTC Smart F3188 internet settings for aircel
For this problem contact the service provider.
PC suit for HTC F3188 you can download here-http://www.htc.com/www/supportdownloadlist.aspx?p_id=311&act=sd&cat=all
1. Download the PC suit .
2. Double click the exe file to run it.
3. Follow the instructions given to you.
4. When installation has completed, the program will open and you can connect your HTC F3188 without any problem.
software112.com/products/htc-pc-suite.html
you can download the pc suit in www.htcmobile.comin this website search your model and then download the pcsuit.
http://www.avaxdownload.com/352/dl/Free+Htc+Smart+F3188+Pc+Suite+Download.html
Good Luck.
Source: i need pc suite for
