I hv erase all sertting..last night after tht my i phone is not working the apple logo appears only for atlest 20 mints nothing happend after tht i will automatically restarted and when i reset tht i phone its appaears again and agian...and i phone is now also not connecting with i tunes....if its connect with i tunes then i will instal the frimware guide me how should i connect it with itunes...i m waiting
1. Re-start Itunes 2. Turn off the iphone 3. Connect your iphone to your computer while holding the Home button (at the bottom of the iphone face) for 15 seconds 4. Itunes will show a screen allowing you to restore your iphone.
A video guide: http://www.youtube.com/watch?v=M2foiTBSn3k
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Your iphone might already have that version, or maybe the phone does not have service, or also it could be tht the phone has been jailbroken. try doing a reset by holding the home buton, and power button down at the same time until the apple logo appears. Then try again
if you have an Apple logo stuck on the screen) try the following sequence of steps:
Hold down Select / Menu (to reboot the iPod)
As soon as the Apple logo appears, hold down Rewind / Select until...
...you see a backwards Apple Logo.
At this point, you will have entered Diagnostic Mode. It'll
test the RAM, and then tell you to HIT PLAY TO CONTINUE. Hit 'Play'.
You'll be in a menu that you advance by hitting FF (Fast Forward). Advance to the 'DISKMODE' entry.
Hit 'Select.' This will put you into Firewire Disk mode. The
screen should change to the familiar 'Do Not Disconnect' mode. At this
point, connect it to the computer.
Run the restore utility; it should now recognize the iPod and
offer to Restore the factory software. Do so. You'll lose whatever's on
it, but you'll avoid having to send it back in to Apple and pay them
$49 or whatever to do basically the same thing. :-)
Try a reset: Press and hold the wake/sleep button and the home button simultaneously for ten seconds and the apple logo should appear on the screen. Release the buttons and it should work like normal. Hope this helps.
