How do I manually get our tv off Video 2 and on to channels so I can watch tv? Remote died while children had tv on Video 2 to watch a movie. Went to menu manually but choosing antenna was not an option. When we chose Menu, here are the options: clock audio (r) picture/sound initial channel (r) antenna (r) channel search (r) channel scan memory (r) menu language The ones with a (r) next to them appear in red. Can't access those options at all. Pravin suggested using Menu to select Imput but it is not an option. Now what?! thanks, LAJ
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
