Question about Ovens
Simpson wall oven 2001 wont turn off unless its turned to automatic.
Oven will not turn off when turned off at knob, will only turn off when you turn the hand knob to auto....
  • glen1961 Feb 20, 2012
    thanks Adam we will give it a go; xxxx
    New Friend:
  • 3 Answers
Oven thermostat is faulty. needs replacing.
Posted on Feb 17, 2012
6ya staff
SOURCE:
Lollo Pop
  • 134 Answers
SOURCE: Simpson 2001 wall oven lamp
phone 131350
Posted on Aug 29, 2009
Tony Woodruff
  • 3 Answers
SOURCE: simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Posted on Feb 22, 2010
e-Guru
e-Guru
  • 3917 Answers
SOURCE: Simpson Harmony Nova wall oven. I
Hi
Please check this link to order the part :-
http://www.repairclinic.com/
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 12, 2010
vijaivee
Vijaya Kumar
  • 120 Answers
SOURCE: Oven door not fully closing
some problem in the lock change the lock
Posted on Jun 12, 2011
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: Hi, I have a 'Simpson
sounds like the thermis to me
Posted on Sep 12, 2011
How do I turn off Auto on oven
Hi Anita,
A quick search of Google for an answer to my question "Turning Auto Off on a Fisher and Paykel Oven"
With little more detail from you like model and if AUTO Off as with Timer I could pin point it, i..e.be more accurate.
So if my guess is correct than it should be on the Analogue/Analog Timer Knob OR if electronic somewhere on the keypad, electronic touchscreen? pad....meaning set it to MANUAL....have you tried that?
Cheers
Nov 02, 2014 | Fisher and Paykel Ovens
Oven failer
You have reset the timer from the auto function, to the manual function.
You should see a hand symbol showing for manual operation.
It is a question of pressing the buttons in the correct sequence., or if it is a anologue timer, turning the knob until you see the hand symbol showing.
Hope this helps.
Dec 24, 2009 | Zanussi ZBF360X Electric Single Oven
My oven wont work afte a power cut its flashing oo:00 auto and I dont have a manual
you have 2 buttons one pops out for adjustment the other is only a push button push the left hand one repeatedly till a red clock symbol shows at top of clock then turn right hand knob to set time wait a few seconds and clock will set itself.
Nov 16, 2009 | Neff B1421 Electric Single Oven
How do I reset the clock on a shacklock multifunction oven? Has 5 buttons, timer, a picture with what looks like steam above a square, auto/man and a knob that can turn either left or right.
press timer (picture with bell) adn cooktime ( picture with what looks like steam above a square) buttons simultaneously while turning adjacent knob clockwise until readout registers current time. Release both buttons and clock is reset.
Oct 09, 2009 | Ovens
Removed dial knobs, put back on oven doesn't work
possibilities are that the spindle retaining clip is missing giving the impression that the oven thermostat is being turned when infact it i s slipping, or the oven is in auto mode if timer model.
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven not heating
If it has a digital timer, make sure it is set to auto and not manual, as oven will not heat if it is on auto.
If it is a anolgue timer ,then it should be showing a hand symbol,if it is not, then turn knob or dial until it does.
If these settings are o/k, then could be a faulty element.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Ovens
My whirpool oven display reads stop, how do i turn it off?
Hi
This "STOP" message appears when either the cooker has been switched off at the mains or there has been a power cut. What you have to do is a s follows:
1. The knob on the left should be turned anti-clockwise ONE click only.
2. Press the button between the two knobs (under the display) ONCE only. You will now have got rid of the word "STOP" and it will be replaced by _ _ . _ _ symbols.
3. Press the same button twice more or until "12.00" is shown. This is the 24hr clock and can the be adjusted up or down by turning the right hand knob clockwise or anti-clockwise. Its always recomended that you set the clock before useing the oven although you dont have to.
4. Now you can operate the oven as normal.....Good luck with that!
Regards Ian W.
Jul 31, 2008 | Whirlpool AKZ159IX Oven
Self cleaning frigidare oven FEF368CCTD
If this stove has knobs, Make sure the clock keeps time. If it doesn't you will have to manually turn this off. (DON"T FORGET OR LEAVE WHILE CLEANING) Make sure there are no large puddles of oil or grease on the bottom of the oven.If the oven is really dirty it may stink a little. Nothing but the racks can be in the oven.Press the lock button and slide the lock lever to lock the door. Set the stop time for 3 hours and turn the knob by the clock to auto. Turn the oven knob to clean. (MAY have to push to turn all the way to clean) It should start heating up. Let it finish and then cool down. It will not let you unlock or open the door until it is completely cool. Wipe out any remaining ash with a wet rag. ALL CLEAN!
Jun 28, 2008 | Ovens
Whirlpool Generation 2000+ oven
Yeah just turn the left hand knob to the one setting which isn't a cooking function - I think it looks a bit like a dash - and then power up as normal on the right hand knob.
It happpened to me but you get the hang of it and it's not a fault.
Sid
May 18, 2008 | Ovens
Tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
May 07, 2008 | Ovens
Ovens Logo
301 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
