Perfect for Home, Shop & Hobbyist. * Input: 115V AC, 60Hz, 270 Watts. * Output: 13.8V DC. * 12 AMP Constant/14 AMP Surge. * Powers Cellular Phones,12V DC CB Radios, Scanners, HAM Radios, Autosound Systems. * Screw Terminal Connectors. * Electronic Overload Protection w/ Auto Reset. * Short Circuit & Thermal Protection. * Fuse Protected. * LED Condition Indicators. * Heavy Duty Cabinet & Heatsink w/Anti-Skid Rubber Feet. * Dimensions:7.87'L x 7.16'W x 4.72'H
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Description
1 50A** I/P fuse panel 2 - Not used
3 - Not used 4 - Not used
5 - Not used 6 50A** Anti-lock Brake System (ABS)
pump motor
7 30A* Powertrain Control Module (PCM)
8 20A* Power door locks, Remote entry
9 - Not used 10 - Not used
11 50A** Starter relay, Ignition switch
13 20A* 4x4 Motor 14 - Not used
15 - Not used 16 40A** Blower motor
17 20A** Auxiliary cooling fan 18 - Not used
19 - Not used 20 - Not used
21 10A* PCM memory 22 - Not used
23 20A* Fuel pump motor 24 30A* Headlamps
25 10A* A/C clutch solenoid 26 - Not used
27 - Not used 28 30A* ABS module
29 - Not used 30 15A* Trailer tow
31 20A* Foglamps, Daytime Running Lamps (DRL)
32 - Not used 33 15A* Park Lamp
34, 35, 35, 35 & 37 Not used 38 10A* Left headlamp low beam
39 & 40 Not used 41 20A* Heated oxygen sensors
