Question about Cuisinart DCC-1200 Coffee Maker
Coffee maker doesn't brew anymore
Hi, it was working fine and now water evaporates more and drips less. I get no more than two cups or less after a long time.The self clean button keeps turning on. I tried cleaning it a few times but it didn't help...
  • 17 more comments
  • Offie J Nov 19, 2007
    I started to brew coffee and the water just drip slowly and the self clean
    button lights up and the coffee I got is more than one cup which is very
    unusual.
  • Anonymous Dec 05, 2007
    I've done the selfclean process with water and white vinegar 4 times. Light goes off, then comes back after second brew. Also see a lot of steam come out through top, which makes water evaporate, therefore leaving me with maybe 2 cups of (terrible) coffee when I actually filled reservoir with 6 cups of water.
  • Anonymous Dec 15, 2007
    I have the same problems mentioned in the other comments except when removing the orange tube connected to the heater it was relatively fused to the metal, and it tore and now it's too short to use. Since it it connected to a heat source I don't want to get the wrong material
  • bramley4 Feb 25, 2008
    our coffee maker was wroking very well and then it over flowed once from having too many grinds. Not is turns on and steams but we don't really get any water going through the drop system so we don't get any coffee. Please advise?
  • Anonymous Feb 29, 2008
    I add the similer problem , but unscrewing the bottom was not possible because of the special screwdriver needed. I used a flexible 24" x 1/4" pipe and used vinigar that I suck up the pipe, turn the coffee maker to on or self clean and push the straw into the bottom of the water holding tank and force the vinigar to go throught. suck up more and redo. once done run vinigar as you would make coffee and filter the partical out and voila it's clean.
  • HLR_Otter Mar 01, 2008
    Same problem as others. Self-Clean light goes on, no water flows into the coffee. Had to make it this morning with a teakettle. Not good.
  • jdaq Apr 08, 2008
    My coffee maker is doing strange things. When I set it to brew the light would sometimes come on and sometimes not. Now the green light for brew never comes on. So, I don't know if there's a problem with the way autobrew etc. have been set. I've tried to do what it says in the manual but nothing seems to be working. I would appreciate any help.
  • Jennrockmay May 04, 2008
    My cuisinart keeps going into self cleaning mode, I have tried to cleanig it with vinegar and it will work a couple of times, but still brews vey slowly. I don't see anywhere where I can take parts out and rinse them from the coffee grinds. I am frustrated and have no idea what to do.
  • Anonymous May 27, 2008
    It worked perfectly yesterday and this morning only two cups of coffee came through. Water stayed in brew basket. Help please? I love my pot.
    I cleaned out the basket and use only paper filters. Still same thing.
  • Anonymous Jun 13, 2008
    tHE COFFEE POT SPITS AND SENDS OUT STEAM BUT VERY LITTLE COFFEE COMES INTO THE POT. HAVE CLEANED WITH VINEGAR AND WATER . NO CHANGES HELP
  • Anonymous Jun 24, 2008
    It will run and gurgle for a long time and yield little if any coffe. I have thoroughly cleaned it but it just has suddenly stopped working properly.
  • KaJiHa Jun 29, 2008
    hi all - thanks for these tips - they are exactly the same problem as i have. I started to try and tackle it but really struggling to undo the base - i think i have the right size and type screwdriver but can't seem to get any traction as the screws are really far down inside - any suggestions? Thanks
  • Jandrae Sep 06, 2008
    my coffee pot just turns off randomly as the coffee is brewing. I have to continually turn it back on. Does anyone know why? Or how to fix it?
  • Anonymous Sep 08, 2008
    The brew switch dosnt work.....
  • Anonymous Sep 25, 2008
    Put in 8 cups of water and only get 5 or 6 cups of coffee. We've cleaned it with water and vinegar according to instructions and the self cleaning light no longer flashes. It also seems more noisy when brewing and takes a lot longer to brew.
  • drmarym Oct 06, 2008
    My cuisinart coffee maker just began having a brewing problem---only half of the water put in, comes out through the filter and into the pot.  The rest of the water steams out.
    Please help the caffeine deficient
  • cklein1 Nov 03, 2008
    We have a fairly new DCC-1200W Coffee Maker, after a couple of months use the self cleaning light started to flash indicating that it was time to do a cleaning. I followed the cleaning instructions prcisely as instructed in the manual. It worked. After another month the light started to flash again, so I did another cleaning. Two weeks have gone by and the light is flashing again. I am not sure if it needs cleaning or if the button is defective. Any answers?
  • arte shelton Feb 04, 2009
    put in 6 cups and 4 cups come out. Very slow and gurgles a lot. Its like a tube is loose or leaking air.
  • Blairmoor Apr 25, 2009
    anyone know a source to buy a new check-valve?
  • 3 Answers
I had the same problem. I read this article and was able to figure it out the probem: http://home.howstuffworks.com/coffee-maker.htm The one way valve and the heater pipe in the bottom of the unit are extremely calcified. I opened the bottom by removing the four little "security" screws. I used a little tiny flathead screwdriver because I didn't have the proper "star security screwdriver and it worked fine. Next, I removed the two orange hoses and soaked them in white vineager. The shorter intake hose contains the one way valve. make a note of which way you remove this hose 'cause it has to go back in in the same direction. Next I propped the unit on its side so that I could put some vineager in the heater pipe and let it soak in there. Next I blew into and sucked air out of the one way hose and then rinsed both hoses thoroughly. Then I used a little piece of a wire coat hanger to scrape out some of the junk in the heater pipe, (especially on the heat side) followed by a little pipe cleaner to get it extra clean. Then I put it all back together. Be carefull that the hoses are sealed ok. I actually cut a little off of them to get a new seal on the side that connects to the heater pipe. There wasn't much room for error though. After getting it all back together I ran a few full pots through it of 1/2 vineager 1/2 water and then a couple of just water. Probably a good time to change the water filter inside the unit too. Also, from now on I'll make sure to use the self cleaning mode more often. Good luck. Kevin
Posted on Nov 20, 2006
  • sonyaknight Jan 03, 2011
    Thanks superkev. We followed your information exactly since our problem was the same--Years of using the machine with no filters. On my way to Bed Bath and Beyond to buy filters. Now that my machine is working again, I don't want to go without coffee
    thanks. SONYA
  • adamawong Apr 18, 2012
    Thanks! i removed crud from the valve by blowing through it really hard and all is back to normal. send me a paypal bill to adamawong@gmail.com and I'll send you 20 bucks!
    Problem Solver:
  • 19 Answers
I agree with superkev2000's posted solution, and had to use the same trick to open the enclosure. BTW, I replaced those security Torx screws with Philips-heads of same
size.
In my case, however, there was essentially zero flow of water from the tank to the heater, and this was traced to a plugged poppet valve in the silicone tubing running from the bottom of the tank to the heater.
I had no luck clearing the clog using a wire or compressed air, so after pulling the hose from the heater, I carefully worked the valve out of the hose by pinching the upstream
end of the hose, having noted the original distance between the valve and hose end.
Be careful removing the valve! There's 1/8" nylon ball that's held in a nylon cage by the hose, so be sure to catch it before it gets loose.
In my case, the valve and upstream end of the hose was TOTALLY clogged with a dark brown granular substance, which I took to be the activated carbon from a ruptured "water purifier" bag by the former user (I got mine used from the Goodwill store for $8).
Clearing the junk from the valve and the hose did take some effort, including a tubing
brush inserted from the tank end. Once the crud was cleared, water flowed freely
from the tank and out of the free end of the hose.
Reinsert the valve cage and ball in the hose, rounded end first, and work it back to its original location.
Preventative action: Don't use those pricey carbon filters! If you need filtered water,
get it from a separate source, like a Melitta or distilled from the store.
Posted on Jan 19, 2008
Removing the base and cleaning the tube w/ one way valve fixed the issue on my coffee maker.
Few notes:
- The screws holding down the bottom plate are a pain to get out... one actually stripped and I ended up ripping the plastic off of it (w/ the other 3 screws undone). Not pretty, but whatever.
Used a flat edge screw driver a little WD40 to pry off the tube w/ one way valve (one facing right when coffee maker upside down w/ pot opening facing you). Tube was glued on and part of the end tore off / stuck to metal; however, I was left w/ just enough to secure again.
Also, gave the coffee maker a few good shakes upside down and 3-4 coffee beans fell out... glad I did this in case these guys were to linger and reclog things.
Definitely won't be using that little charcoal filter anymore... I think it ruptured and also contributed to issue.
Thanks Fixya!
Posted on Feb 03, 2009
Thanks all for the great info.
I was having the same issues - 12 cups water, 10 cups coffee and lots of steam.
I removed the orange tubes where the check valve was. Tubes were clean, so I checked where the check-valve was located. Bingo! A piece of coffee bean was lodged between the little black ball preventing fast water flow.
Thanks again. :)
Posted on Jul 31, 2008
Mine quit working, too, I took it thoroughly apart, and THEN had the smart idea to look online for solutions. I was highly motivated after not getting any coffee this morning and swilling some of the nasty black dreck they call "coffee" at work. Here's what I found and how I fixed it.
I think my unit is about 4 years old, dosn't have an "autoclean" feature but looks identical.
1) Problem: A whole lot of steam, and not very much coffee-- what there was, tasted ok though. Problem caused by: using it for three years while completely ignoring the charcoal filter- either replace them once in a while or pull it out completely. My bolts were standard Torx, didn't have a center pin.
2) The wrench needed is a #10 torx key (similar to a hex key, but the corners are sharper. Any hardware store has them, either individually (cheap) or in a set.
3) the hose appears to be made of hi-temp silicone rubber, I removed mine without any damage by carefully pushing one part of the end back to the end of the tube with the flat side of a blade screwdriver. The tube with the check valve is the one on the right, when the unit is upside-down, with the pot opening toward the front. The tube is easily removed by squeezing together the two sides of the clamp, and the other end pulls off easily. Then the check valve can be pushed out with a screwdriver, and cleaned (watch out for the tiny check ball! about 1/8 inch dia.
4) Yep, that check-valve was thoroughly gunked up with charcoal from the filter! Somehow I didn't lose the ball. The "X" end of the checkvalve should face the underside of the unit (towards you when putting it back together. I took mine apart in the sink, and made sure to seal up the drain first.
Posted on May 15, 2008
Had the same issue this morning. Followed the above steps, blew out the orange tube and now the coffee maker works much better. Less steam, less noise and hotter coffee.
Posted on Oct 12, 2008
Great info from all. I found water leaking out of the bottom of the unit. Figured it must be a cracked hose. Could not get the bottom screws out until I found the post re: #10 torx. Since my screws have the center "security" post, I used a #9 torx and it worked. I am disappointed in you Cuisinart. These are great units that could yield years of service. Stop trying to make them disposable by installing shorter than necessary tubing. My tube with the check ball valve was cracked and when I carefully pulled it off, it left its end glued to the heating element. Barely enough to grab, but I pulled out the valve, turned it around and replaced the hose by opposite ends. This worked great. I would feel better if I could just replace the tubing with a longer piece. Perhaps a fuel line or heater hose from an automotive store would work. It could handle the high temps. Any suggestions?
Posted on Jun 24, 2008
All of the above were helpful. The solution from W5VSI
helped the most. I was getting flow in both directions from the check valve. After it was squeezed out of the tube, we found a small pice of yellow kitchen sponge stuck in it with a hardened wad of coffee behind it. Once this was cleared, it worked fine. As wraned, remember which way the check valve goes back in!
Posted on Apr 20, 2008
  • 3 Answers
I applied the solution of opening the bottom of the coffee maker (mine is a cuisinart timer model without the grinder). When opening it, I removed the orange tubes from the ends which were NOT clamped and simply used a fine tip turkey baster and pushed vinegar and water mix through the tube and unjammed a LOT of coffee that had overflowed from above into the system. I made sure to hold the end of the tube over the sink, and push the fluid in through the end that is removed from where the filter goes,a s the one-way valve will allow the fluid in that direction. I just successfully "brewed" a pot of vinegar to ensure all is flowing well now. Thank you for the great tip!! I am so happy to now have to replace this unit as it costs about $70 new.
Posted on Dec 23, 2006
    New Friend:
When I pulled mine apart, the ball fell out, but I don't know which end. Any suggestion as to which order? Is it:
water supply-ball-valve-heater?
Or
Water supply-valve-ball-heater?
In other words, if I put the ball between the valve ring and the heating element, are we sure it won't fall into the heating element and melt???
Posted on Apr 28, 2014
Thanks to all. Great info on the DCC-1200.
Mine had a piece plastic stuck in the one way valve.
Two things. The "tamper torx" screw can be removed with a mini flat blade screwdriver about 1/16" wide. Try a couple different sizes so you find the right one. Also, be extra careful when removing the hose from the heater element. The hose end seems to be glued to the aluminum. I ripped the hose, but still had enough left to reinstall it.
Posted on Apr 29, 2008
The posted solution worked. I was trying to pull the short orange tube off the heater element and it tore off, leaving 1/2 inch of tube glued to heater element. Luckily there was enough length the to put the tube back on the end of the heater element nad use the clap to re-attach. I scraped bunch of gunk from the check valve. It all went back together and did not leak. So a successful endeavor. Thanks Fixya.
Charles
Posted on Mar 03, 2008
Found that a #10 torx driver works for the screws, just not the one with the center post.....nice one cuisinart :<
Posted on Feb 17, 2008
Finally gave up trying to figure out why the DCC-1200 wouldn't pump water from the reserve to the coffee filter and google'd it.
The posted solution worked great.
The only problem I had was getting the four bottom screws out.
Got three with a modified screw driver but had to drill the fourth screw out. Replaced the original screws with three phillips head screws and everything works good now.
Since I don't use tap water (only filtered water) I don't think I need one of the expensive filters.
Any comments????
Posted on Jan 21, 2008
SOURCE:
!0 Cup home Bunn. Does not brew the number of cups of water coffee (water) in craft. 8 cups of water 6cups of coffee.
If you don't brew often enough you will loose a small amount of water in the tank due to evaporation while the tank heater comes on and goes off to maintain the proper brewing temperature, so if it has been a while since you last brewed, without coffee in brew basket put a carafe of water thru the brewer, you will get less than a full carafe out because it fills the evaporated space in the tank first then uses the rest to brew. Once your tank heater shuts off usually 5 minutes on less you will get out all the volume you put in.
Oct 11, 2014 | Bunn 10 Cup Home Coffee Brewer
Only 1/2 cup or less of coffee brewing. Water is going back into the reservoir at brewing tim.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 03, 2011 | Keurig Elite B40 Coffee Maker
Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Mar 25, 2010 | Keurig B60 Coffee Maker
When I put in, 6 cups of water, if the 10 cup Bunn coffee maker after it has sat overnight, it only expels about 4 - 4.5 cups. I don't think it can all be evaporating or being absorbed in the grounds can...
look for water leaks around pot. Otherwise do a daytime brew to compare your difference between the amount poured in and what comes out. Please note that less water should mean using less ground coffee. Suggest 1 heaping table spoon per brewed cup.
Feb 10, 2010 | Bunn 10 Cup Home Coffee Brewer
Barely any coffee rises to upper chamber after cooking
It's the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Also cook on medium to low heat. High flame seems to make the problem worse.
Jun 28, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Coffee maker with grinder--sometimes, when percolating, it overflows
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Jun 28, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I have a new Z5 (less than 300 cups) that began dispensing a slow and reduced volume of coffee and also began leaking approx 3 oz of water into the tray after just 2-3 cups of coffee. I have meticulously...
If the grounds are really wet and not looks like a round firm cake, you need to use coarser grist on the grinder. The water in the drip tray is coming from the brew unit. The o-rings are not holding the pressure inside because the sieve is clogged. It could also be that the o-ring are dirty, then the brew unit needs to be disassembled and cleaned.
A good way to controll if the grist is too fine, is to watch if the coffee is just dripping from the outlet. Then try adjusting the grinder until the coffee flows evenly. You can also hear if the pump works harder during brewing.
Apr 26, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Cusinart 12 cup grind and brew overflows with grinds and water
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart DCC-1200 Coffee Maker Logo
21,264 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
