I WANT THE FIX FIRMWARE FOR MY PRINTER WITH V2.01.01.01 AND SERIAL IS
Dear
As the firmware locked and can not update without the serial no. Therefore you may try on line firmware generators, who are selling for money.
http://www.firmwaregenerator.com/
Firmware fix
Thanks.
SOURCE: I have a SAMSUNG SCX4623F
We have SCX4623 Ver. 99 FW
also provide generator.
www.chipresetters.com
skype : indianrefiller
SOURCE: how to uprade the firmware
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
SOURCE: Firmware updates for hp CLJ 47000dn
you can down load and software and firmware for free from HP's website.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: Reverse Firmware Upgrade
http://www.fixyourownprinter.com/forums/printer/56368
There are two different print engines used in the CLP-300. One for
2006, and a different one starting in 2007. I have the older 2006
printer, and the current firmware is only for the new 2007+ print
engine.
I talked to Samsung support here in Korea and fixed the
problem. They sent me to their special tech support website at
www.1479.co.kr (only in Korean) and I was able to download an older
version of the firmware which restored my printing ability.
The latest version of firmware that worked with my printer was found in this post: http://www.bassmania.co.kr
Download
the two files at the top, then extract the archive. Drag-n-drop the
correct firmware file onto "usblist2.exe" and the printer will be
flashed with the firmware (must be connected via USB if you're using
the CLP-300N model).
SOURCE: can't connect the Brother PC fax v2 in a home
You need to set the IP address correctly in the Network Settings.. Make sure it corresponds with the routers IP address and is on the same Network... what I mean by this is .. the gateway should be 192.168.1.1 or similar the printer should be 192.168.1.10 or in that fashion... the 1 after the 168 is the network and the last number of 10 or what ever is the number the device is on the network.. sort of like a home address on a city street.. sounds like you need a person there that knows how to set this up properly... to connect it to the router and configure it properly... Look up a Geek!
If you are troubleshooting a system or OS problem, you should not consider firmware updates until after exploring more typical troubleshooting steps like file system error checking and anti-virus scanning.
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
