SOURCE: Error message when trying to send pictures
Are you with ATT? I got notified Yesterday by ATT that they are having Widespread Multimedia Problems at this Time. Should be fixed by Next Week.
i work at a cell phone support group called ict, we get this problem all the time with the lg phones. the problem is with the carrier select in the programming. have your phone reprogrammed...you will need to contact your service provider for you lock code, but you can usually get into the programming screen by dialing ##program# or ##data# from the main screen of the phone (you do not need to dial this number or hit ok once putting in the last #, it will automatically pop up if you are doing the right code. again, you will need your lock code from your service provider/carrier. once you have that go into the programming and go to carrier, high lite which ever carrier you are with, hit ok and the phone will shut itself off, turn itself back on and you should be able to send your picture without further problems..
...if it then asks you for a pass, call your service provider, they also need to give that to you and if it says error 256 after that, then call your service provider because the url needs to be changed...
hope this long winded post helps you guys.
SOURCE: I can't send pic/video messages
As of February the LG Rumour will be one of the phones MTS/Sprint's new operating system will not cover for Video/Picture Messaging. Even though it's never worked for me since I got the phone, now they are completely making it impossible for you to use that feature. My question is why are they advertising that feature then?
SOURCE: lg vu internal error message
Does it give an error code? That could help to better define the problem. Mine does this and then gives me "Internal Error 22"
I haven't been able to find out what causes
it. What I've found works is when you get the internal error 22, go to
your messages outbox. The message you are trying to send will be
listed there and will probably still say "sending". Cancel sending.
Then resend. I don't know why, but this has worked for me. Hope it
helps you.
SOURCE: Unlocked LG Vu won't send or receive picture messages
http://tmobileuspublic.wdsglobal.com/phonefirst
This Fixed my phone.
if it fixes yours then please repost it so you can help someone else!
thanks!
