Justin, The orientation switch for the LCD module is located on the horizontal shaft which supports the monitor. The switch can be damaged or break off inside the LCD cabinet and cause this symptom. Also, we have seen the harness rubbing against the metal bracket and tear which causes the signal to be lost which directs the microprocessor to invert the image. I hope this helps you. Joe Weibel CustomElectronics.Org
