THE WIRELESS LIGHT WON'T EVEN LIGHT UP. IT WON'T CONNECT TO ANY INTERNET. THE WINDOWS VISTA PROGRAM JUST CRASHED AGAIN, AND I HAD IT RE=INSTALLED AGAIN. AFTER THAT, IT QUIT DOING INTERNET. I DOWNLOADED A NEW WIRELESS CARD FROM DELL, AND IT DIDN'T MAKE A DIFFERENCE. ANY HELP?
IS THE WIRELESS SWITCH TURNED ON,ALSO MAKE SURE YOU HAVE WIRELESS CARD IN LAPTOP,IF YOU HAVE VERISON DID YOU GET DISK,IF SO DOWNLOAD IT.OR GO TO CONTROL PANEL AN CLICK INTERNET CONNECTIONS,CLICK ADD WIRELESS CONNECTION.IT SHOULD OPEN WIZARD TO HELP YOU CONNECT.GOOD LUCK
You sayin you download the new drivers for the wireless card? Check your device manager tab in control panel and see if the networks adapter is red or yellow. It should say what is wrong with it
SOURCE: Load XP in Dell inspirion 1525
If U want to change ur pc's os to WinXp the go to dell.com and choose Ur country after that go click on the support link or support and driver link then choose ur laptop after that choose the operating combo box to winxp(sp2) and if there is driver's are available or not in most cases Every Dell laptop has xp(sp2) drivers............
Shubham.................
SOURCE: locked out by password on dell inspirion 1525 how do i re install vista
If you have the vista disk, then just put it into the drive, and reboot. You may need to change bios boot order, which can be done by pressing f8 as the computer starts up, and selecting the dvd drive. If this does not work, then please refer to your user manual for the correct key to press. If you can boot, then the installation is self explanatory. Give it you country and keyboard layout, and then when the screen shows "install vista" button, undeneath it is a repair vista button link. Click this, and select your existing installation. From there it may ask you about "system restore" press cancel, and then hopefully, it will restore. Hope this helps.
SOURCE: i need latest xp drivers for dell inspirion 1525 laptop-
Hi I am Vortash I personally would go to, C-net .com and get all the drivers I need . but if you are not to familiar with this practice you could download a program called driver detective and it will update all your files for you .but you do have to pay for this service .. Alternitvely go to your manufactures support site and download all the latest drivers from them depending if you know what drivers you need .. finally you can search for updates in windows at microsoft.com from the update shortcut in your start menu hope this is of help tp you regards Vortash
SOURCE: Help! My Dell Inspirion 1525 laptop crashed, black
0F00 errors are hard disk drive errors. You will need to replace the hard drive. If under warranty, call Dell Tech support. If not, then you can buy a new drive from places like Newegg.com
