Click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
In the bios there's an option to configure SATA as "IDE", "AHCI", or "RAID". If you don't have data to loose, try this. Install the drive, set the
BIOS option to "IDE", boot to windows, install manufacturer's IDE/SATA
controller drivers, restart, set the BIOS option to "AHCI".
AHCI stands for Advanced Host Controller Interface. There are rumors
that setting AHCI without manufacturer's drivers will give you a BSOD.
I'm not sure if you can recover it by switching back to "IDE", but it
should be worth a shot. Best of luck
BATTERY Microsoft AC Adapter Microsoft ACPI-Compliant Control Method Battery
COMPUTER ACPI Uniprocessor PC
Diskdrive Universal HDD
DISPLAY Mobile Intel (R) 915GM/GMS, 910GML Express Chipset Family Mobile Intel (R) 915GM/GMS, 910GML Express Chipset Family
HDC Primary IDE Channel Secondary IDE Channel Intel (R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
INFRARED SMC IRCC - Fast Infrared Port
KEYBOARD Keyboard 101/102 keys Microsoft Natural PS / 2 Keyboard
MEDIA Audio codecs Video Codecs Midi Control devices Legacy Video Capture Devices Legacy audio drivers Microsoft Kernel System Audio Device WDM Audio Compatibility Driver Microsoft WinMM Realtek AC'97 Audio
MOUSE PS / 2 mouse
NET 1394 Adapter Remote network engine Miniport (IP) WAN Miniport (PPPOE) Parallel Direct IR Realtek RTL8139 Family PCI Fast Ethernet NIC WAN Miniport (L2TP) WAN Miniport (PPTP)
OTHER DEVICES PCI Modem
PCMCIA Generic CardBus Controller
PROCESSOR Intel Processor
SDHOST SDA Standard Compliant SD Host Controller
SYSTEM Generic Bus Button ACPI resource sixed Button tie / Untie ACPI The system CMOS / real-time clock Direct access memory controller Programmable Interrupt Controller Microcode update device Microsoft System Management BIOS Driver Software Device Enumerator Plug and Play Logical Disk Manager Manager volumes Intel (R) 82801FB/FBM SMBus Controller - 266A Intel (R) 82801FBM LPC Interface Controller - 2641 Intel (R) 82801 PCI Bridge - 2448 Microsoft ACPI-Compliant Embedded Controller Microsoft ACPI-Compliant System Microsoft Composite Battery PCI bus PCI standard host CPU bridge ISAPNP port Terminal Server Device Redirector ACPI Terminal Server Keyboard Driver Terminal Server Mouse Driver System Timer
UNKNOWN PCI FLASH memory
USB Intel (R) 82801FB/FBM USB2 Enhanced Host Controller - 265C Intel (R) 82801FB/FBM USB Universal Host Controller - 2658 Intel (R) 82801FB/FBM USB Universal Host Controller - 2659 Intel (R) 82801FB/FBM USB Universal Host Controller - 265A Intel (R) 82801FB/FBM USB Universal Host Controller - 265B USB Root Hub USB Root Hub USB Root Hub USB Root Hub USB Root Hub
This error message could be caused by a number of things. Generally it's because the program being downloaded is corrupt or didn't download completely. Have you tried a different browser to do the downloads? If it's a very large download you may encounter problems with losing packets. A download manager may help. http://www.techspot.com/downloads/231-free-download-manager.html
Also, you may want to try doing a restore to system restore point to a date when you weren't having this issue. System Checkpoint dates (in bold) are usually very safe points to restore to. I would also recommend a virus scan and if you don't have this utility and are able to download and install it (yes I know that's your current problem, but you can download it to a flashdrive from a friend's comp and install it), I'd get Glarysoft Utilities and run the one-click maintenance which will fix any registry errors. It's free and is a great way to keep your machine running well.
If any of this helps correct your problem I would appreciate a rating. People here seem to take the help and don't show any appreciation by taking the time to rate the help.
