I have only used 84% of the lamp life but the display only shows black & white. When I click the menu the window appears in color but the background image of the movie is still B&W.
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
I opened mine up hit the red reset in the front and now all good. If ur red light is blinking make sure ur lamp compartment is shut properly, if not the red light will blink and unit won't turn on.
the colorwheel may be bad. if it doesn't spin, the lamp won't strike. if the colorwheel is ok, replace the power supply/ballast. you can get one and do it yourself, or send it to a sharp service center. either way, try www.avsolutionsny.com. they're really good.
have you reset the lamp timer yet? can't remember the procedure for that one exactly often hold power and down and left arrows whilst plugging in power. Check info on instructions that came with your new lamp.
Hi, You can download user manual of Sharp XR-11XC from HERE for free as website will ask you any of your email address only. User manual has all info about this unit.
You may have to reset the Bulb Life Timer. When the power is turned on, you simultaneously press the "right arrow", the "down arrow" and the "menu" buttons, then press the "standby/on" button, it should zero out the Bulb Life Timer and it should come on.
