Was at school the other day and noticed my drivers side rear door wasnt locking or unlocking with drivers controls inside truck nor with remote. door is latched securely and all other doors work as should locking and unlocking. i can push the button down on the door and it will lock and unlock but wont do it without me doing it manually.
SOURCE: Dodge Ram 1500 can it have a plow?
Yes It can and It should not void the warranty. Contact your dealer.
SOURCE: can't open quad cab door on 1998 dodge ram 1500
just finished tonight with the same problem on my 2000 ram, i cut the studs out with a drimel tool, and also the latch, with this out of the way the door opened easily,, have to replace bottom latch later . total time about 1 hour tigerhunting
SOURCE: 2004 Dodge Ram 1500 Quad Cab Drivers side power door lock broken
Sounds like the link rod to the latch are jammed in the locked position by something inside the door or it came off. Any way, you have to remove the door panel to get access to it.
SOURCE: I need a diagram for the serpentine belt on a 2002
get a hane repair manul it should have a diagram in it .you can get one at the auto parts store
SOURCE: 2006 Dodge Ram 2500 diesel truck----need inside fuse box diagram
If you are looking for the fuse box diagrams or any other diagrams for your Ram, check promanuals.net for a factory service manual for around 20 bucks or so. It's an invaluable tool for my Ram 2500.
