How can I retrieve messages by calling in from another phone
Go to Google..enter Sony tam 100 manual..this will instruct you on how to set up the access code 00-99 or how to change an existing one.
Normal 0 false false false MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}table.MsoTableGrid {mso-style-name:"Table Grid"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Instructions for Retrieving Messages While Away from Home
Sony TAM-100 Answering Machine
Step I: Set the Remote ID (security code) on themachine itself:
1 Press (SET/REC).
2 Press (ANSWER ON/OFF).
A voice guide will say: “Pleaseset the security code. To select, pressthe SKIP or REPEAT button. To enter,press the SET button”.
3 Set a two-digit number between 00 and 99 bypressing (SKIP/QUICK) or (REPEAT/SLOW). Press (SKIP/QUICK) to increase a number, or (REPEAT/SLOW) to decrease.
Each time you press (SKIP/QUICK)or (REPEAT/SLOW), the answering machine announces a number.
4 Press (SET/REC). The remote ID code (security code) is set,and you hear a long confirmation beep.
To change the remote ID code(security code), Enter a new remote ID code (security code). The new code will replace the old one.
Note: If a powerinterruption occurs, the remote ID code will not be erased.
Please See Next Post to Continue (my response exceedsallowable text restriction ;-) ).
Normal
0
false
false
false
font-size:10.0pt;
Step II. Retrieving New Message(s) from a remote phone
1 Call your phone from a touch-tone phone.
2 While you hear the greeting play, press
(#), and your remote ID code (security code).
A long confirmation beep will
sound and the greeting message will stop.
The voice guide will announce the number of message you have. Enter the Control Code (security code) within
20 seconds.
Follow Table below to perform desired function:
Remote Phone Operation /
Function Code (Press)
Play back messages in
MAIL BOX 1 # 1
MAIL BOX 2 # 2
MAIL BOX 3 # 3
Repeat the current
message #
4 (during message playback)
Skip the current message
# 6 (during message playback)
Erase the current
message #
9 (during message playback)
Erase all the messages
in MAIL BOX 1 # 9 then # 1
in MAIL BOX 2 # 9 then # 2
in MAIL BOX 3 # 9 then # 3
Record a new greeting * 7 A long beep (up to one minute) will sound. Begin recording
your greeting. Press * * to stop
recording.
Turn on the answering
function * 0
Turn off the answering
function # 0
Stop the current
operation *
To quit, simply hang up
the phone.
My apologies for the formatting garbage posted above each of my posts/instructions.
If you'd like a copy of the original owner's manual, please leave me your email address.
Thanks!
Gail
SOURCE: Retrieving messages away from home.
When you are away, you call your number and waiting for the welcome message (your message). When the machine invites you to leave a message you enter your secret code, the one you entered when you configured the machine. (Usually there is default, but since you don't have a manual there is no point guessing (although 123 may do the trick). Some older phones have a code sticker on the underside of phone.)
When the code is recognized the machine starts giving instructions press (number) to (do something).
Hope it helps.
