Philips DECT 2252S Cordless Phone Logo
Posted on Oct 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Philips cordless phone message indicates "keys locked"...can't dial.
Have two hand sets...primary one indicates the "keys locked"...which means I can't dial with it.....the second hand set is OK. How do I unlock the keys.
Thanks, djm
  • 2 more comments
  • Anonymous Oct 31, 2008
    Same problem with Philips SE445
  • kliment ilincev
    kliment ilincev Jul 06, 2014
    how to unlock kejs on philips ce 0168
  • Brian Reeder
    Brian Reeder Apr 20, 2016
    It is really the (0) button with the key symbol under it not the astrix.
  • Diane
    Diane Apr 02, 2018
    Thankyou.it worked...husband dropped phone...I,ll throw it away he said....I said I,ll find an answer!...
Anonymous
Level 2:
Sergeant:
  • Expert 236 Answers
  • Posted on Dec 05, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
236
Questions
0
Helped
104519
Points
654
You should have a key symbol on the * key. Press and hold this to turn on and off the lock feature.
here is your phone manual
  • onedawoman7
    onedawoman7 Jan 30, 2012
    awesome solution, rather intuitive, but I did not figure it out, although I did get the pulse to tone thingy changed on my own.
  • Anonymous Apr 20, 2016
I have an answering service through my phone company and I would like to use that option, rather than the answering system that is built into the phone. Right now when messages come in, the phone provider...
Dial your own number, when the voicemail picks up, dial either the * key or the # key. Then follow the instructions for setup that they give you. There should be an option for notification settings within the voicemail system.
1helpful
When I pick up the receiver to dial out, it beeps and beeps for about 6 times before I can dial
each beep means a new voice mail...so 6 beeps should indicate that you have 6 new voice messages :D just dial your voice mail and check them and it will stop!!!!! :D
GOOD LUCK AND PLEASE RATE THIS POST!!!!!!!!
7helpful
PANASONIC KX-TG2340JX TROUBLESHOOTING
my small dghutor turn the dial lock on by mistake .we trry to turn it off but we couldn't coz we don't know the password No. so plz hellp us the Model No KX-TG2340JX Panasonic
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
1helpful
Uniden TRU8885-2 Restarts every time an incoming phone call, start showing the Welcome message ....
YOUR batteries are bad and not giving full current to phone.Clean charging contact and see battery gets full charge. IFthe battery indicator will show full charge due to voltage but once if you remove battery and put it again indicator will be minimum. then replace batttery.
4helpful
2answers
Use call phones through voip321
It took me a while to figure out but here is how I am able to dial out from skype to a hardline to a person not in my skype contact. Simply start to dial the number (not from the talk button!!!) then instead of hitting the talk button to dial, hit the skype button on the bottom left hand side. I also have to dial 001 then the phone number. Hope this works for you too. good luck.
VS205 what does the flashing mail sign mean?
If you subscribe to call answer service with your phone company, a mail indicator might coincide with a stuttering dial tone, to indicate a message waiting. If on the Bell Canada network, dial *98 to check your voicemail. Once all new messages have been listened to, the dial tone will stop stuttering, and the indicator will hopefully follow suit.
1helpful
Indicator message light on handheld phones do not go off!!!
on the base set, press and hold the voice mail 1 button. You will get a message clear voice mail indication? hit the sel/save button to the left of the display.
poof! message gone
2helpful
To turn the blue light off
What worked for me was to call my phone and leave a voicemail. I then retrieved and deleted my voicemail which reset my handsets.
I hope this helps!
Top Philips Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
