2002 Honda VT 1100 C2 Shadow Sabre Logo
A
Anonymous Posted on Feb 13, 2012
2002 Honda VT 1100 C2 Shadow Sabre flush the radiator
5 Related Answers
Anonymous
  • 28 Answers
  • Posted on Dec 28, 2008
SOURCE: 2006 honda shadow sabre backfires
valves need to be adjusted every 6000 miles your way past due also your carbs need to be in sync together a shop has to do this work
Anonymous
  • 83 Answers
  • Posted on May 18, 2009
SOURCE: how to change sparkplugs on honda shadow motorcycle
VT1100 has two spark plugs per cylinder, the sparkplug caps are snap-ons so they're fairly easy to remove. You need a spark plug socket wrench to remove and replace the spark plugs.
Anonymous
  • 1392 Answers
  • Posted on Jul 22, 2009
SOURCE: need to tighten the timing chain
It has an automatic cam chain tensioner. If you are getting cam chain rattle, I would look at worn guides/chain.
Anonymous
  • Posted on Jun 25, 2010
SOURCE: how to check water level for my 2002 honda shadow sabre
the easiest way to see the coolant level is to shine a flash light up from underneth the plastic tank, located between the the engine and rear tire. now follow the fillcap located above the right side passenger foot peg. there will be a vertical one inch slot in a chrome cover. behind this slot are two very faint lines . one low, one high about a half inch apart. I found that carefully tilting the bike to the right makes it easy to see just how low the coolant is. a really small diameter piece of tubeing jammed into a tiny funnel will prevent a mess when topping off.
Anonymous
  • 87 Answers
  • Posted on Aug 22, 2010
SOURCE: How much oil does the
with the oil filter it should be 3.7 quarts
I have a 2002 Honda VT 1100 C2 Sabre and I just flushed all of the oil out of the pan and also changed out the filter. How many liters of motor oil do I have to put back into the reservois?
I have checked my service manual and it does not state quantities just top up the oil until the glass level is up to the mark. Don't forget the oil filter will take a little extra oil.
Sorry
1helpful
Is the only way to fill the coolant for my Honda Shadow Sabre 1100 is by the small cap near the passengers right foot peg?
I filled my radiator with coolant by removing the cover on the right side of the gas tank just behind the handle bars. When you remove the cover, you will see the radiator cap. Remove the cap and begin filling with the appropriate coolant.
3helpful
2answers
Where is the radiator drain plug for a 2002 honda shadow sabre
This is correct. I just changed my coolant on my 2002 1100 Sabre and all you have to do is disconnect the lower radiator hose and drain all of the fluid out, flush with fresh water, then reconnect and fill with appropriate coolant.
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
