SOURCE: treadmill won't run the screen is showing E7
You probably need a technician to look at it. I would say the motor that runs the treadmill is faulty due to a fuse that has blown you would have to locate where this is first replace it and proceed to the nxt step. I say you may need a technician cos often you are dealing with mains power or small dc voltage in any case one should carry this out in a safe way.If you are not confident ring a professional Tech.
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
I had the same problem. I even ordered a $300 controller board. The new board didn't work either. That's when I started checking voltages from the control board to the motor. That was good. Lastly I checked the brushes. Almost nothing left. . . The motor started working again after I put everything back together. I need to order new brushes and return that contoller board.
SOURCE: Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.
machine runs for half a minute then shuts off. Try again the run time is shorter and eventually it won't run
