Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal
operation) bottom edge of soap dispenser or caked powder fallen onto
dishes or dishwasher bottom. There may be loose powder in rest of
dispenser or spilled down inside door or onto dishes underneath
dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many
dishwashers the top tray has an indentation as wide as the lid of the
dispenser. This allows the top tray to be as large deep as possible
while still allowing space for the dispenser lid to open. People often
pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery
or crockery prevents the lid from opening all but a few degrees. Some
water will splash in but not enough to wash out the soap powder. The
soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly
open, will of course swing fully open and you'll be convinced that the
lid opened normally during operation. If this is the problem then if
you're very careful and open the door very slowly you can actually hear
the lid flip open. Also, depending on when the lid opens, how far it
opened during operation and how fast you open the door you may find soap
powder spilled down to cover the dishes at the front or down the inside
of the door. This happens when you first open the door and obviously
there couldn't be loose powder there if the powder had emerged while
there was water washing around. Seeing the lid open as you open the door
is a lot harder but can be done on some machines.
I a little puzzled.. It is physically impossible for the lid to fully open. The bottom of the top rack is, quite simply, in the way - there is no gap in the rack to allow for the dispenser lid to fully open. The dispenser lid will open to about 75 deg. +/- (something less than 90 deg.), but won't open any further. This is NOT because of anything overhanging or loaded incorrectly, and this IS the rack that came with the unit. Is this a design-flaw, or is this (dispenser lid only opening to appx. 75 deg.) acceptable. My detergent does not fully dissolve and clumps are almost always left over in the dispenser. Any help on this wouyld be apprecitated..
I too have had this problem>It would only occur in times of no hot water, or delayed hot water operation.If your hot water heater is a long way from the washer this can happen<eventhough it doesnt seem to happen consistantly>the solution would be to try to run the hot water in the sink nearest to the washer until it gets hot,then start the dishwasher. The soap despenser is one of the first steps in the proccess,and if the hot water had not been run in a while it could take up to 3 minutes to reach adequate temp>good luck hope this helps
Daniel
I also have the same problem, some soap left in the soap dispenser after complete wash is finished.
